Did you know? 🤔
98 XC: VERY bad starting sound after replacing injector seals
CIK7
Year and Model: 1998 Volvo V70 XC
Has thanked: 69 times
Been thanked: 3 times
United States of America
CIK7
Re: 98 XC: VERY bad starting sound after replacing injector seals
Post by CIK7 » Fri Jun 19, 2020 4:59 pm
scot850 wrote:
Fri Jun 19, 2020 4:17 pm
Have you tried to remove all the spark plugs and manually turn the engine over? If you thing the started has seized, remove that before trying this and see if the engine has frozen. No point condemning the engine to quickly. Removing the starter will also not be wasted as you will need to remove it if the engine is wasted anyway. Can you borrow a boroscope? If you can you can put it down the plug holes and look for damage on the piston crowns and broken rings. Also check the crown wheel teeth for damage where the starter motor was when it seized (assuming it did).
I am ever the optimist and hope that your engine is not done!
I won't be able to attempt turning the engine over until I can get my friend's breaker bar. on Tuesday I will remove the starter and attempt to turn the engine if possible.
1998 V70 XC black ($1K trade, Mi:143,995/151K, immaculate engine, totalled 5/2/20)
1998 V70 XC white ($50 cash, junk, donor for my black XC)
2001 V70 Ba white (sold)
2009 Impala LT 3.5L (sold)
Plans for my 98 XC: 16T/18T, P2 M66 swap, logo/badge delete excl grille
wizechatmgr
Has thanked: 24 times
Been thanked: 61 times
wizechatmgr
Post by wizechatmgr » Fri Jun 26, 2020 6:40 pm
Make sure those plugs are out first - that gas needs a place to go...
1999 V70 XC AWD - ~190k miles
CIK7
CIK7
Post by CIK7 » Sun Jun 28, 2020 10:38 pm
no gas in chambers. intake Port#2 from passenger side and entire intake manifold was full of gas.
Has thanked: 14 times
Been thanked: 230 times
Canada
Post by scot850 » Sun Jun 28, 2020 11:28 pm
If that is drained out or vented off, with all the plugs out will it then turn over by hand?
2006 XC70
2015 Kia Sportage EX-L
2000 V70 SE NA - New project and test bed - Sold
Year and Model: 2001 V70
Has thanked: 36 times
Been thanked: 75 times
Post by volvolugnut » Thu Jul 02, 2020 5:41 pm
CIK7, any progress on troubleshooting?
2001 V70 T5, 1986 244DL, 1983 245DL, 1975 245DL, 1959 PV544, multiple parts cars.
Hardtofool
Year and Model: V70XC 2000
Has thanked: 0
Been thanked: 0
Hardtofool
Post by Hardtofool » Thu Jul 02, 2020 7:43 pm
What kind of injectors did you buy? Where they oem?
