A couple of years ago I had the a/c pulley off and took out a shim to set the a/c clutch factory clearance. The car hasn't seen many miles since so I'm pretty confident the setting is correct. But the clutch isn't engaging with the a/c and recirc switches set to on, and the blower fan at 3.
There's a relay under the dash. I don't remember the electrics.
Guidance on where to start troubleshooting would be appreciated.
96 Volvo 850 a/c clutch not engaging
- misha
- Has thanked: 155 times
- Been thanked: 432 times
First,take the car to ac shop to check freon level.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
I knew the freon was down since there's a slow leak, probably in the dash. I charged it last year and it was okay for the summer. Today, I put the gauges and vacuum pump on it, registered about 5 lbs + pressure before pumping. It took just a few minutes to get to minus 30. Then when it wouldn't take freon from the can I discovered the clutch wasn't turning.
- 22 Replies
- 9335 Views
Last post by 5ft24
- 699 Views
Last post by aspireToRepair
- 1417 Views
Last post by MiddoV70
- 13 Replies
- 4720 Views
- 919 Views
Last post by Jat007
