Just did a 1000km trip in my 239k 2001xc70. My trip computer at start of trip said 11litres/100km but is now saying 9.6L/100km i think thats around 29.12 Miles per 1 US gallon (not sure)
Is this good for a 19 year old car?
29.12 Miles per gallon 2001 xc70 Topic is solved
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- Has thanked: 987 times
- Been thanked: 1075 times
What was average road speed during this trip? Mostly highway or city? What engine do you have?
- Been thanked: 4068 times
About 25 mpg. Decent for an XC on motorway
That’s infinite miles to the gallon according to L’Hospitals Rulejonesg wrote: 18 Jun 2020, 14:30 on a long trip 400 -800 miles I creep up to 28mpg. otherwise 24mpg.
2004 V70 turbo....thats all torn apart right now.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
There are a driving variables as well as "mechanical" ones that influence quite a bit these numbers
As mentioned above, 120kmh (75mph) vs 90kmh (55mph) gives very different mpg
Tire pressure, wheel geometry, tire size also matter a bit, winds
"Mechanically" speaking, can influence a lot, injectors not having a good spray pattern, faulty O2 sensor, spark plugs, air filter, piston compression, PCV, various sensors..
- darrylrobert
No motorway/highway, alot of winding steep climbs and decents. speed from 100km/h max to 80km/h alot of road works. Engine is 2.4T manual, used cruise control on the few straight sections, generally drove like an old man.
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
On both our P2 cars (2003 V70 2.4 NA auto and 2005 S80 2.5T auto) I found that the onboard mileage calculator always indicated SLIGHTLY worse MPG than if I calculated actual fuel burned vs actual miles traveled. I also found that I could get better mileage by NOT using CC. CC doesn’t have the ability to look down the road and “anticipate” what power will be needed to climb the next hill and slowly increase the throttle ahead of the hill in order to avoid laboring the engine and causing unnecessary downshifting, etc. Conversely for when you see a downhill coming - you can start letting up on the gas ahead of time.
- oragex
Steep roads will indeed take a tool on mpg, even if you also go downhill, I think uphill mpg is a lot worse than downhill 'savings'.
Also going from 80 to 100 (60mph) means accelerations, another factor
I feel you are not far from the right numbers at 10l/100km given the conditions for the turbo AWD, I would be have been surprised to see 8l/100km. How is city mpg ?
