Fixing 850 lower front bumper damage
SonicAdventure
Year and Model: 1996 850 wagon
Has thanked: 59 times
Been thanked: 12 times
Post by SonicAdventure »
As part of the prep work for eventually installing the fog lamps, I need to address this pre-existing damage to the driver side bottom part of the bumper.
I was hoping that some aftermarket “R” style lower lip would be available that would attach with adhesive tape. Ideally, it would fit perfectly along the existing lower horizontal line. Then, I could patch what still shows of the crack from behind the bumper and do whatever cosmetic fix seemed most reasonable for the front side.
I’ve looked all around and can’t find a lower bumper lip, even though I swear I’ve seen them in photos from other forums. Anybody got any leads or other ideas?
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
850R extensions available from here. Well recommended company here in the UK and I know he's had quite a few international (including the USA) customers.
Has thanked: 2199 times
Been thanked: 1852 times
Or you can buy a plastic welder and repair it. I did with a bumper that had 2 'bunny ears' caused by someone running over and then backing off a concrete parking bay stop block. Once painted you could not tell. We have a store here called Princess Auto that sells the unit for about $70 CDN which comes with what looks like a propane powered soldering iron with different tips and fill sticks for different plastics.
Bumper has not split again.
https://www.princessauto.com/en/detail/ ... -p8699134e
Harbor Freight might carry something similar. Pro Point is Princess auto own branded products.
