I am going to install the little fan 6/44 onto my ecm box. Would it work if i connected to the ecm as per thus wiring diagram, or would the ecm need programming?
Should i just connect itindependently with a thermostat?
little fan wiring question 2001 xc70
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- SuperHerman
- Been thanked: 207 times
Do you have a picture of the actual physical fans (original and new).
Looking at the wire diagram it appears to be a standard brushed fan as it has only two wires feeding it, unless 6/44 is some kind of connector. If two wires I don't see how it would take programming - on/off input would be from elsewhere as well as voltage control (if it has it) to vary the fan speed.
A few pictures would help.
- darrylrobert
As per the wiring diagram the fan has a pos+input and -neg input .It has two functions, fan on ...fan off. This can still be controlled by the ECM via a ground input. My question is does the ECM need to be programmed using VIDA or is it "plug and play"?
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
oops, forgot to test mine before it went dark.jonesg wrote: 21 Jun 2020, 23:57 ... there is no downside to having the fan always run when ignition is on.
I'll go out later and check mine, I have an extra ecm fan from the junkyard.
Tues for sure.
- SuperHerman
I doubt that their is software on the fan assembly. You can look up the part and dig around to see if there is a software download associated with it.
Again, look at the fan - if there are only two wires and you can power it on and off with external voltage it is a straight brushed fan. Speed control, if any would be via the associated computer, which is separate and upstream.
I don't see the wire diagram showing a ground point, which it should if the fan has one. The housing is also plastic so grounding is problematic. My take is it is just a fan in a fancy plastic enclosure. No software.
- jonesg
Its 2 two wires only.SuperHerman wrote: 22 Jun 2020, 21:14 I doubt that their is software on the fan assembly. You can look up the part and dig around to see if there is a software download associated with it.
doesn't turn on with ignition on, ecm ground switched.
My timing belt is off so I couldn't test engine on.
The 2 prong socket connector is be located behind the box, clipped to the inner fender.
Fuse #8 , also controls acc pedal sensor and AC.
- SuperHerman
I am a bit confused. Are you retrofitting or repairing/replacing?
My original reading of your request was that you were replacing an existing fan.
If a retrofit then it may require the ECM to have that instruction and it may require some trigger sensor which tells the ECM it is getting warm. I have no way of knowing, but I do recall there is a dangling harness with no mate floating around unused, at least in a few of my prior Volvos.
Assuming you have a dangling harness and it is a mate, plug the fan in. Take a hair dryer, and with some intelligence, while the car is parked and running, add heat to the ECM. Again with some intelligence as all you want to do is get the ECM warm where it would want to turn on the cooling fan. That will give you your answer.
The fan in the photos is a typical brushed motor - speed would be controlled by changing voltage, if the motor is not run at a single speed by the ECM it may always be on by design. Only way to figure this out is to see if someone with the fan installed can verify operation. I have seen posts where people just swap out the motor as a repair for failed units (not sure which brand of car though).
If you are retrofitting a fan for additional cooling, and your car does not have a fan harness already installed, you can just hard wire it and let it run all the time. But I do have one concern, if the ECM is handling the voltage, it may not be 12Vs, it could be 6Vs. There should be a part number or specs on the motor telling you what the voltage range for the motor. Other way to tell is have someone with a fan read the voltage the fan is getting when operational.
- 1121 Views
Last post by carboncow
- 1595 Views
- 5727 Views
Last post by gnalan
- 1832 Views
Last post by 2000c70hpt
- 605 Views
Last post by julesvern
