Do any of you know the size of Volvo Driveshaft Flange Bolt size? Is there only one size? The previous owner replaced them with regular bolts and I'm afraid that they will rust.
Is this the right size ?
M8x40mm - 9183941
M8x25mm - 988143
Volvo 99 V70 R Driveshaft AWD bolts 988143 washer 1385088
- Has thanked: 2202 times
Sorry for my lack of understanding, do you mean the bolt in the end of the front axles at the hub, or the prop-shaft bolts?
Are you talking about the ones with the internal hex heads?
- kklepack
- Year and Model: 2016 XC60
- Has thanked: 12 times
- Been thanked: 5 times
Sorry for not being clear yes prop-shaft bolts internal hex heads number 7scot850 wrote: 22 Jun 2020, 12:24 Sorry for my lack of understanding, do you mean the bolt in the end of the front axles at the hub, or the prop-shaft bolts?
I need the washers - number 6 as well
- Screenshot from 2020-06-23 13-06-06.png (82.35 KiB) Viewed 1851 times
If you don't still have the washers then yes you will need them too. They do not have locking tabs so not sure what the purpose is but perhaps the flanges needed re-inforcing?
- kklepack
In case someone else has the same question.kklepack wrote: 22 Jun 2020, 14:41Sorry for not being clear yes prop-shaft bolts internal hex heads number 7scot850 wrote: 22 Jun 2020, 12:24 Sorry for my lack of understanding, do you mean the bolt in the end of the front axles at the hub, or the prop-shaft bolts?
These are the part number I was looking for and FCP confirmed that they will fit my car. Thanks all
#6 DRIVE SHAFT WASHER PART NUMBER: 1385088
#7 DRIVE SHAFT BOLT PART NUMBER: 988143
- Been thanked: 4068 times
Added part numbers to title for search
I went looking for info on these bolts
Are they single use?
What are the torque spec?
Can someone with VIDA FILL that info in here please?
- kklepack
I have placed an order for them, so when I go to pick them up I will ask the guy in Volvo parts store.Hope he knows,abscate wrote: 17 Jul 2020, 04:30 Added part numbers to title for search
I pulled a set of 6 bolts and the 3 link washers earlier this week. The bolts are re-usable (I have done so many times).
Sorry to be too late to this note as you could have had the bolts and links.
I will see if I can find the torque settings later on today for you. They use a 6mm Hex Key.
- 1477 Views
- 14 Replies
- 8840 Views
Last post by Willber
- 36 Replies
- 24730 Views
Last post by StickyPocket
- 1309 Views
Last post by Nevada1906
- 15 Replies
- 8728 Views
Last post by volvolugnut
