Hi, i am rebuilding a S60R 2004 model some of the electric connectors in the engine bay are missing. I down loaded a wiring diagram free from the net but it seems to be missing the pages that identifies the components. and some of the component of the R are also not shown. ( VVT solenoids. Cam sensors ect) can someone may assist with wire colours for these components.
Thanks
identify electric components
- SuperHerman
- Been thanked: 207 times
mirage - can you provide more details. Specifically what is the story on the car, did it come with an engine harness? Is the original engine remaining? Are you putting in a different engine?
What wire diagram are you using? Generally the wire diagram references a connector via a number.
Maybe with some more detail we can help you get this sorted, but right now there are too many unknowns to even start.
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
I use an online wiring diagram downloaded (free) and have found it fairly accurate.
Keep searching the internet, i have not been able to find a wiring diagram for my 2001xc70 but the 2002xc70 is close enough.
Some of the wire colours have been changed through the years. you really need to use a multi-meter to track each wire.
here is a pic of the VVT connector 8/18
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
Thanks for the image,The previous owner had the head casket blow, and cooked the engine. he ended of by cutting off a few connectors to replace on a project car. thank you for the effort I will try and search the net for more info
- 1977 Views
Last post by Juan62
- 1944 Views
Last post by precopster
- 1580 Views
Last post by beigg
- 13 Replies
- 5510 Views
- 15 Replies
- 3152 Views
Last post by ogatrulle
