Did you know? 🤔
1999 S70 GLT Rear Suspension Upgrade Order
2001 - 2007 XC-70
ericmci
Year and Model: 1999 S70 GLT
Has thanked: 3 times
Been thanked: 0
United States of America
ericmci
Post by ericmci » Tue Jun 23, 2020 4:00 pm
Hello,
I have a 1999 S70 GLT]
I am replacing the majority of the rear suspension- Shocks- Springs- Delta end links and the transverse arm mounts.
Just wondering if there is a preferred order for doing all of these at once, i.e. does having the springs and shocks out relieve pressure for the delta and transverse mounts?
My plan as it is now is to do Delta links(I have the special Volvo factory tool to help with these) and Shocks- then springs so that I can use the jack points on the spring cup since I am doing this on the ground. And finishing with the the transverse mounts.
I had considered mounting the car on the reinforced tire jack center body pin jack points \ but they don't really sit well in jack stands without the sides of the jack stand digging into the body, unless you cut a notch in a 2x4 to place on top of the jack stand to distribute the weight- which is a possibility.
As long as the transverse mounts can be replaced without having to remove any other components I might just do everything else first do those last with the rest of the suspension system in place.
Can anyone thing of better order to facilitate all of this?
Thanks in advance!
-Eric
Has thanked: 336 times
Been thanked: 1035 times
Trinidad & Tobago
Re: Rear Suspension Upgrade Order
Post by abscate » Wed Jun 24, 2020 4:07 am
You need to block the car closer to the work area . You should’ve able to get jack stands under the axle beam and do one side of at a time.
I don’t think the springs interfere with the delta link job
Link To Volvo Glossary
ericmci
Been thanked: 0
ericmci
Post by ericmci » Wed Jun 24, 2020 11:57 am
Hey thanks-
So when you axle are we talking about the transverse arms?
If so would supporting the car on one side be balanced enough to remove the transverse arm mounts one at a time?
cbpitt01
Year and Model: 2006 V70 2.5T
Has thanked: 1 time
cbpitt01
Post by cbpitt01 » Sun Jun 28, 2020 2:17 pm
Hi Eric,
You’ll probably get more interest and responses in the correct forum. This one is for 2001-2007 V70 & XC70 and 2001-2009 S60. Good luck! 🙂
2006 V70 2.5T, Ice White with Arena/Oak, bought “newsed” @ 183,500 miles in Dec 2015; 225,000+ miles as of May 12, 2019!
Trinidad & Tobago
Re: 1999 S70 GLT Rear Suspension Upgrade Order
Post by abscate » Mon Jun 29, 2020 5:15 am
Bumped to the P80 Forum
xHeart
Year and Model: 13XC90/01V70X/97N854
Has thanked: 20 times
Been thanked: 42 times
xHeart
Post by xHeart » Mon Jun 29, 2020 11:25 am
Hey thanks-
This thread may help a little viewtopic.php?f=1&t=65148
Golden Retriever | 2014D VIDA DiCE | 2013A XC90 +144mi/231km | 2001 V70XC 1st Owner +196mi/ +315km | 1997 Volvo 850 NA 1st Owner +180mi/ +289km
Past: German Shepherd | 1989 Volvo 740 GL | 1979 Volvo 240
