98 s70 glt rough start [P0304 P0305 , swapped plug wires] Topic is solved
stephansvolvo
Year and Model: V70 GLT 1998
Has thanked: 21 times
Been thanked: 3 times
Post by stephansvolvo »
Finally got the engine back together. Started up and ran good for about 2-3 minutes. Smelled very rich and idled very rough. It almost seemed as if there was misfiring happening or timing is off.
Turned it off. Added coolant and Checked the oil.
Pulled off the timing cover just because.
Tracks light is on, check engine light is on, arrow is flashing with the e and w button lights.
I’ll pull codes in tomorrow. Codes show mid fire 4/5 as well throttle position sensor.
Any help with any of this would be great!
IMG_0666.MOV
(68.01 MiB) Downloaded 162 times
Stephan
84 240GL my first(sold)
88 240GL(timing belt killed it)
98 S70 GLT
73 IH Scout ii
stephansvolvo
Codes are misfires and TPS?
Stephan
98 S70 GLT
73 IH Scout ii
Has thanked: 1610 times
Been thanked: 4065 times
Show us the inside of your distributor cap and rotor up close
New plugs and age of spark plug wires?
bronco
Year and Model: 1998 V70
Has thanked: 49 times
Been thanked: 24 times
Post by bronco »
abscate wrote: 30 Jun 2020, 05:05 Show us the inside of your distributor cap and rotor up close
melted rotor !!! with a milkshake on the side
..For the win!!
( we still need the pictures - its Covid Days)
:lol:
MVS Volvo Horns.jpg (76.73 KiB) Viewed 1707 times
stephansvolvo
Brand new plugs wires rotor and cap.
Stephan
98 S70 GLT
73 IH Scout ii
Has thanked: 2200 times
Been thanked: 1852 times
Brands please of the parts as many are not compatible with these engines or can be hit or miss.
stephansvolvo
scot850 wrote: 01 Jul 2020, 11:38 Brands please of the parts as many are not compatible with these engines or can be hit or miss.
All OEM. Bosch cap and rotor, bougicord Volvo plugs.
Stephan
98 S70 GLT
73 IH Scout ii
Pull the plugs on #4 an #5 and check they are not wet. There is another thread running where the owner was having leaking injectors after a re-build.
The fact you have all these issues it could be one of 2 other things and or a bad battery:
1) Electrical portion of the ignition switch. It can cause all sort of mayhem. Did you try switching off and re-starting?
2) I had random lights coming on and weird running and it was the ABS module of all things.
The other thing could be a bad connector or air/vacuum leaks.
Not sure why the TPS is showing as a code.
stephansvolvo
So dumb! I had the 4/5 switched even after I checked them. So no codes except the secondary air code. Tracs, ABS and service light are on but, I think we can figure those out.
Thanks for your help on yet another one.
IMG_0710.MOV
(51 MiB) Downloaded 140 times
Stephan
98 S70 GLT
73 IH Scout ii
