I own a 2004 XC70 I have had the AC repaired multiple times. I just picked up my car. And true to form it didn't last till I got hiome. This has been going on for about the last three summers.
Is there a magic sequence of new parts? I have all my slips and can list what has been done. I can't be the only one with a 16 year old XC70 with this problem. Any suggestions?
AC not working each time it is repaired
It sounds like someone isn't leak testing it to make sure it holds charge, which is a basic function of an AC Tech
You should have it pumped down to vacuum and then test to see if it holds it. If not, you have to add a bit of refrigerant and use a leak tester to find the leaking components.
Do you lose all cold air or does it start cold and then go warm on you??
At least in one month you won't need it in the Pine Tree State
- June
- Has thanked: 523 times
- Been thanked: 261 times
Expansion valve is likely bad. Replaced my 04 S80s last year. I'm assuming your car is not leaking freon that fast. The S80 would work intermittently and always while in for service naturally... if it's a freon leak, Abscate is right it will just have to be leak tested. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
it wasn't repaired, sounds like they just gassed it up and shipped it.Sunnypenny wrote: 26 Jun 2020, 14:34 I own a 2004 XC70 I have had the AC repaired multiple times. I just picked up my car. And true to form it didn't last till I got hiome. This has been going on for about the last three summers.
I'd find a place that listens to what I tell them.
or start researching DIY.
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
I have found that the Schrader valve where refrigerant is added often goes bad. Few people ever replace it and it is relatively cheap. I replace it as preventive maintenance if I find my A/C system needing a charge. It is often all I need to do to restore 100% functionality.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
I was looking at the a/c radiator in the front of my 2001 xc70 and it seems the (mouth) air scoop has collected a few more rocks, I might put installing a mesh on the "urgent modification" list. This is the first place a technician will look at for damage/leaks.
The previous owner "updated" the front and rear bumpers, i have removed that lightbar, it looks stupid there.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Would also help letting us know what (or how) specifically is not working. No cold air at all, intermittent, not cold enough ?
Sunnypenny
- Year and Model: 2004 XC70
After going through the slips for the last two years. I have determined they have only been re freoning. Not doing a leak test, So I will specifically ask to cheak for leaks, and NOT just fill with freon. I thought they understaood when I said the AC is not working. Works for a short time, then no cool air. I guess my language or my discription got lost in translation. (oh, I speak English and was born in Massachusetts) Thank you for all your input and replies. It was helpful.
- oragex
Works for a little then no cold air is the typical compressor clutch problem, would not have to do with the freon levels. Google up about 'ac compressor bread clip fix'. Needs handy finger to do it, but it should cost a decent $0. A mechanic that knows where to place clips or even sip tie should be good to do it in about 30 min or so
There could also be another issue if the air is still cool but very little air comes out off vents after 5-10 min. But if airflow is good just stops being cold, it's the thing above
- 2409 Views
Last post by beardedbmx
- 760 Views
Last post by jbkeene
- 1233 Views
Last post by brunocerous
- 796 Views
Last post by mikespencer
- 1009 Views
Last post by precopster
