Did you know? 🤔
AC not working each time it is repaired
2001 - 2007 XC-70
Sunnypenny
Year and Model: 2004 XC70
Has thanked: 0
Been thanked: 0
United States of America
Sunnypenny
Post by Sunnypenny » Fri Jun 26, 2020 2:34 pm
I own a 2004 XC70 I have had the AC repaired multiple times. I just picked up my car. And true to form it didn't last till I got hiome. This has been going on for about the last three summers.
Is there a magic sequence of new parts? I have all my slips and can list what has been done. I can't be the only one with a 16 year old XC70 with this problem. Any suggestions?
Has thanked: 333 times
Been thanked: 1035 times
Trinidad & Tobago
Re: AC not working each time it is repaired
Post by abscate » Fri Jun 26, 2020 3:38 pm
It sounds like someone isn't leak testing it to make sure it holds charge, which is a basic function of an AC Tech
You should have it pumped down to vacuum and then test to see if it holds it. If not, you have to add a bit of refrigerant and use a leak tester to find the leaking components.
Do you lose all cold air or does it start cold and then go warm on you??
At least in one month you won't need it in the Pine Tree State
:D
Link To Volvo Glossary
June
Year and Model: 2004 S80 T6
Has thanked: 320 times
Been thanked: 162 times
June
Post by June » Fri Jun 26, 2020 3:58 pm
Expansion valve is likely bad. Replaced my 04 S80s last year. I'm assuming your car is not leaking freon that fast. The S80 would work intermittently and always while in for service naturally... if it's a freon leak, Abscate is right it will just have to be leak tested. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
jonesg
Year and Model: 2004 V70
Has thanked: 2 times
Been thanked: 24 times
Wales
jonesg
Post by jonesg » Fri Jun 26, 2020 5:08 pm
it wasn't repaired, sounds like they just gassed it up and shipped it.
I'd find a place that listens to what I tell them.
or start researching DIY.
E Showell
Year and Model: V70R '06 AWD Auto
Has thanked: 20 times
Been thanked: 70 times
E Showell
Post by E Showell » Fri Jun 26, 2020 5:51 pm
I have found that the Schrader valve where refrigerant is added often goes bad. Few people ever replace it and it is relatively cheap. I replace it as preventive maintenance if I find my A/C system needing a charge. It is often all I need to do to restore 100% functionality.
'99 V70 NA FWD Auto, dark blue (actively for sale)
'06 V70 R AWD Auto, Sonic Blue Metallic
'04 XC70 Ruby Red Metallic
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
darrylrobert
Year and Model: 2001 v70xc
Has thanked: 3 times
Been thanked: 12 times
Australia
darrylrobert
Post by darrylrobert » Sat Jun 27, 2020 3:26 am
I was looking at the a/c radiator in the front of my 2001 xc70 and it seems the (mouth) air scoop has collected a few more rocks, I might put installing a mesh on the "urgent modification" list. This is the first place a technician will look at for damage/leaks.
The previous owner "updated" the front and rear bumpers, i have removed that lightbar, it looks stupid there.
xc70 mouth
Has thanked: 0
Been thanked: 133 times
Post by cn90 » Sat Jun 27, 2020 6:42 am
Or this could be the slipping clutch all along.
If so, then the fix using zip ties is free.
Info in forum...
oragex
Year and Model: S60 2003
Has thanked: 97 times
Been thanked: 277 times
Canada
oragex
Post by oragex » Sat Jun 27, 2020 10:25 am
Would also help letting us know what (or how) specifically is not working. No cold air at all, intermittent, not cold enough ?
Sunnypenny
Has thanked: 0
Been thanked: 0
Sunnypenny
Post by Sunnypenny » Sat Jun 27, 2020 12:02 pm
After going through the slips for the last two years. I have determined they have only been re freoning. Not doing a leak test, So I will specifically ask to cheak for leaks, and NOT just fill with freon. I thought they understaood when I said the AC is not working. Works for a short time, then no cool air. I guess my language or my discription got lost in translation. (oh, I speak English and was born in Massachusetts) Thank you for all your input and replies. It was helpful.
oragex
Canada
oragex
Post by oragex » Sat Jun 27, 2020 12:56 pm
Works for a little then no cold air is the typical compressor clutch problem, would not have to do with the freon levels. Google up about 'ac compressor bread clip fix'. Needs handy finger to do it, but it should cost a decent $0. A mechanic that knows where to place clips or even sip tie should be good to do it in about 30 min or so
There could also be another issue if the air is still cool but very little air comes out off vents after 5-10 min. But if airflow is good just stops being cold, it's the thing above
