1998 V70 NA Silver Bullet return , exhaust manifold
Has thanked: 1609 times
Been thanked: 4064 times
Question for the collective
The exhaust manifold on MADD Wagon, aka Silver bullet , has the braided part degraded and mostly gone. The accordion part of the manifold looks ok. Is this for strain relief and should I replace the whole thing?
$250<400 for part or used one
Can I find that mesh somewhere and attach it to the existing manifold ?
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
When I worked on cryogenic equipment we used a lot of stainless flex hoses for expansion and misalignment. Talking with vendors for these flex hoses, the outer mesh is used to reinforce the accordion for pressure. It can also be expected to help prevent the accordion section from stretching too much.
If the exhaust pipe is supported downstream, I would expect the mesh is not needed. If you could find a source of the proper size mesh, you would still need a skilled welder to weld to your ends.
wizechatmgr
Has thanked: 45 times
Been thanked: 128 times
Post by wizechatmgr »
Are we speaking of the preheat for the air intake or the exhaust downspout flex hose? If it's part #9, that just heats the air intake on cold days to avoid icing.
Part 1, the actual exhaust manifold.
There is a accordion flange allowing flex between the head and pipe, and then a mesh steel part that seems to either strengthen the flex or damp the motion. That part is corroded away, and that’s the part I have to make a decision on path
See mesh on the FCP picture
Note the fitment note is wrong , these cars don’t have EGR, they have SAS or air injection
Tats not a hard weld if I can source the mesh material but that seems problematic. Cutting open a flex exhaust piece is an option
wizechatmgr
I believe you can buy just a replacement mesh flex section and likely get Mike to weld that without too much issue.
