oil pressure low stop engine safely error
mahmuttokmakci
Year and Model: 2004 2.9 T6
Post by mahmuttokmakci »
could you help about "oil pressure low stop engine safely error"
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Have you searched forum for info yet?
Look for "Oil pan O-rings"...
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
First, don't drive the car, don't even run the engine. Your best luck would be a faulty oil pressure sensor or wire. Otherwise you can have a blocked pick up mesh in the oil pan, damaged o-rings, etc that would require the pan to be removed an inspected. The PCV may be blocked causing oil pan sludge and oil starvation
