Transmission cooler installed
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Rvolvos
Year and Model: 2006 xc70
Has thanked: 73 times
Been thanked: 23 times
Post by Rvolvos »
Got around installing a transmission cooler for our 2006 V70.
Purchase a cooler from Ebay, had already a Magnafine filter installed in an attempt to increase the lifespan of the transmission and 5 drain and refills. Replaced the filter again.
In an attempt to increase the air flow to the radiator I relocated the horns left and right of the air dam. Used the horn mounting point for the upper cooler mounts. The hoses are routed behind the crush bar.
Ambient temperature Was 90 F, measured oil temperature out of the radiator cooler, 80 degrees C , atf going into secondary cooler 75C, going out 35C. All measurements done with infrared thermometer.
During driving max. Recorded transmission temperature with Vida 95C.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
2011 C30 T5 M66 105k Totalled RIP
2006 V70 2.5T 184k RIP
2011 C30 T5 AW55-50SN 99k sold
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Is the stock radiator oil cooler not effective?
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
Rvolvos
Post by Rvolvos »
The general consensus is, an additional transmission oil cooler helps getting the oil temperature down which increases oil life and life of the transmission. I am planning on doing this on all of our cars with an automatic transmission. Cheap insurance.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
Has thanked: 1511 times
Been thanked: 3829 times
darrylrobert wrote: 30 Jun 2020, 08:11 Is the stock radiator oil cooler not effective?
Volvo transmissions routinely run 300k with routine maintenance in stock configuration.
Rvolvos
Post by Rvolvos »
abscate wrote: 30 Jun 2020, 19:32
Well this car ( vin ending with 13) had the transmission replaced by the previous owner under warranty at 100k
When I bought it (140k) started with drain and fills because the transmission fluid was black.
The car Is going to move to SoCal with ambient temperature higher than in NorCal I figured an additional cooler could prolong the fluid life.
Routine maintenance is not recommend by Volvo and none of the first owner do this and sell the car when it becomes old, the one who do, don’t sell the car ;-) I have bought 5 Volvo’s with no maintenance done to the transmission. Last car a white C30 donor car, one owner, family member of Volvo sale manager. No service records on transmission maintenance.
2006 XC70 2.5T 238k
2012 S60T6 95k rip
