Did you know? 🤔
steering wheel shimmy/wobble at hwy speed xc70
2001 - 2007 XC-70
darrylrobert
Year and Model: 2001 v70xc
Has thanked: 3 times
Been thanked: 14 times
Australia
darrylrobert
Post by darrylrobert » Tue Jun 30, 2020 3:46 am
Ever since i hit a dip in the road and bottomed out my front suspension, my steering wheel shimmies/wobbles at around 100km/h but not always, only when i hit a joint/bump in the road.
My first thought was a weight fell off my wheels, but i swapped the fronts for the rears and the problem is still there. Ive been really stressing out that ive damaged my alloys or tyres.
I also suspected the steering rack/inner outer tie rods so ive checked and replaced all that (used parts) but problem remains.
I had booked in to get the wheels balanced checked and steering aligned but a google search said a bad shock can cause this as it looks like ive damaged one or both shocks. I can see oil staining, so ive ordered new factory shocks from Volvo.
I will also recheck carefully the numerous other links and joints.
jonesg
Year and Model: 2004 V70
Has thanked: 2 times
Been thanked: 26 times
Wales
jonesg
Re: steering wheel shimmy/wobble at hwy speed xc70
Post by jonesg » Wed Jul 01, 2020 3:20 am
Look at the control arm bushings too.
oragex
Year and Model: S60 2003
Has thanked: 97 times
Been thanked: 279 times
Canada
oragex
Post by oragex » Wed Jul 01, 2020 7:13 am
Don't forget to look at the tire on both sides of the wall, for any bubbling
As above, check the bushings in CA. For intermittent vibrations, I had problems with the axles. The slightest play in the CV joints or even just a small nick inside the joints can cause intermittent vibrations, depending on the road surface flateness. Maybe try replacing it with a used one that has not play in CV joints. While there, worth inspecting the ball joint or even replace it if it hit really hard
