Did you know? 🤔
P80 Axle shaft Part numbers tabulation, Version 1
Has thanked: 333 times
Been thanked: 1035 times
Trinidad & Tobago
Post by abscate » Tue Jun 30, 2020 12:06 pm
I have tabulated all the part numbers I can find and post images below.
For -1996, it is Hellacious journey into chassis breaks.
From 1997-on isn't too bad
Format is current part number and superseded part numbers in parentheses.
Link To Volvo Glossary
Trinidad & Tobago
Re: P80 Axle shaft Part numbers tabulation, Version 1
Post by abscate » Tue Jun 30, 2020 12:10 pm
And here are the 15 variants of -1996 axles shafts.
Has thanked: 101 times
Been thanked: 294 times
United States of America
Post by erikv11 » Tue Jun 30, 2020 7:06 pm
For the record: I have swapped axles around from my two 96 860s to other P80 cars 95-98 without ever paying attention to part numbers, and never had fitment issues.
These would all be automatic, FWD cars. Mix of turbo and non-turbo although running NA axles in a turbo is not recommended, the outer CVs are not as beefy. I've run turbo axles in NA cars however.
These users thanked the author erikv11 for the post:
'96 855 NA, 145k
'98 V70, T5 tune-injectors-turbo, LPT engine, 286k
'06 S60 R, 167k
'99 Camry V6 :shock: 125k
Trinidad & Tobago
Post by abscate » Tue Jun 30, 2020 7:16 pm
My 1999 had the CV ball and cage style on the driver side, both ends , while earlier models I believe use the spider type.
All those part numbers and yet compatibility still to be determined...
Let’s tabulate part numbers andapplícations here in this thread, thanks erik
Post by erikv11 » Tue Jun 30, 2020 7:18 pm
yes, 99+ are completely different axles from -98 and they are not interchangeable. Frankly I would suggest devoting separate threads to each to help clarify that for others down the road. :D
OK I will pipe down here unless posting part numbers ...
'96 855 NA, 145k
'06 S60 R, 167k
Trinidad & Tobago
Post by abscate » Tue Jun 30, 2020 7:19 pm
erikv11 wrote: ↑
yes, 99+ are completely different axles from pre-98. OK I will pipe down unless posting part numbers ...
Didn’t mean to shut you down at all. :D Knowing which ones can go where is the whole point, and you’ve already made it known that part number exact matches aren’t required
