2005 xc70 transmission oil levels
adrian22
Year and Model: s60 2006
Post by adrian22 »
is it possible that my transmission hard shifts/noisy problem when I brake(downshifts) or start from a stop (upshifts ) is caused by my transmission oil overfill>?
It dipstick level shows around hot top mark when the car sat overnight and is cold with engine off. When you start engine the oil level supposed to drop?-that is confusing to me--whe are you supposed to read the levels?
motor oil is at the same level regardless the engine is on or off
adrian22
Has thanked: 1610 times
Been thanked: 4065 times
The engine oil level will change between sitting cold and running.
A transmission circulates ATF into many moreplaces than the engine, so most manufacturers specific a temperature and conditions to check the fluid level.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
You problems are not fluid related www.youtube.com/watch?v=czDDSwguYR8
adrian22
Post by adrian22 »
the video shows how to measure the levels but what do you mean by problems are not fluid related?
adrian22
