V70R C4 Shock Replacement
I am trying to replace the rear shocks. I have installed the new shock into the top mount which I removed from the car. The assembly will not line up with the bottom pin or top mount holes. Is there a part of the process I am missing or have I assembled it in the wrong order. Perhaps the top mount should be left in place and the parts mated to the top mount. I just cannot get it all to fit I feel like I am missing something. Does anyone know the process for reassembly?
- - Pete -
- Has thanked: 81 times
- Been thanked: 178 times
You should be able to align the spring with the rubber insulator that sits inside the aluminum top-hat the same as it was aligned with the old shock/same configuration as when you removed it from the car. Just look closely at the rubber; it’ll be obvious where it rested against the top-had and also where the spring rested against the rubber.
For the bottom mount, you will need to use a come-ahh-long to “scissor” the rear control arms towards the floor. You may also need to use the end of a ratchet to “turn” the bottom of the strut mount so it aligns with the dowel/lower mount on the control arm. Once it aligns, you will likely need to pound it on with a rubber mallet or dead blow. There’s not much about the process that is truly enjoyable. Just don’t get all worked up, it’ll go back together as before with some patience & a fresh outlook after a break.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
- 1771 Views
Last post by MoVolvos
- 11 Replies
- 1309 Views
Last post by 98v70dad
- 2014 Views
- 1387 Views
Last post by MadeInJapan
- 3643 Views
Last post by Jonboy74
