Strut disconnection from tower w/out affecting alignment
ionianp2
Year and Model: 2004 Volvo s60
Has thanked: 16 times
Been thanked: 10 times
Post by ionianp2 »
Hi Everyone,
I hope all is well. I came across one of Oragex's video's with regards to rust on strut towers and I was wondering if anyone was able to disconnect them from the tower without affecting alignment.
The haynes manual says to take a measuring caliper and "measure the distance from the back of the shock absorber to the outer edge of the hub carrier mounting lug".
I have done that in the past, without much success and I was wondering if anyone did any different sort of trick to disconnect it?
My plan is to clean the area in the inner part of the strut tower, remove any surface rust by sanding (or use a converter), applying some POR-15 over it, and rubberized undercoating over that, with a finish of fluid film (maybe an overkill? :lol: ).
I figured this is a good time since I am not driving the car much and I do plan on keeping it for a long time. :D
Let me know your thoughts.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
I do it all the time - measuring that distance with an outer caliper and putting it back. If you want to be a perfectionist: search Trackace on ebay, it is well worth it. I didn't visit any alignment shops in a few years.
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
i will be doing this over the next few days, i just always marked (scribed) the bolt position on the knuckle and upper bodyof the car but i dont think thats a very accurate method. The camber adjustment is very small almost not worth worrying about.
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
