2011 XC90 AWD should I replace all 4 tires?
For some unknown reason, the front right tire got a crack about half an inch long at the edge of the treads yesterday. It's leaking very fast. One can hear the sound of air going out. I don't think the tire is repairable because the crack is close to the sidewall. These tires are about 15-month old. The tread depth of the front left one is about 7/32. The rear two are close to 8/32. Now my question is should I replace all 4 of them? Can I just replace one or the front two? I see people recommend replacing all 4 for AWD and that's probably the best performance. But these tires are expensive and relatively new. If possible, I'd like to save some money. Thanks for reading and for any suggestions.
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
No, on that model year you can replace only the two on the front axle, and keep the old one for spare
Full tread is 8/32 so one tire is probably fine
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
If the tread is 8/32 and tire is only 15 months old, then , a) you have close to 30,000 miles on these tires with lots of steering time, b) these were not NEW quality tires, c) poor roads it travels, or d) low tread wear rated tires. You may still be under warranty to replace all four.rred wrote: 04 Jul 2020, 12:33 For some unknown reason, the front right tire got a crack about half an inch long at the edge of the treads yesterday. It's leaking very fast. One can hear the sound of air going out. I don't think the tire is repairable because the crack is close to the sidewall. These tires are about 15-month old. The tread depth of the front left one is about 7/32. The rear two are close to 8/32. Now my question is should I replace all 4 of them? Can I just replace one or the front two? I see people recommend replacing all 4 for AWD and that's probably the best performance. But these tires are expensive and relatively new. If possible, I'd like to save some money. Thanks for reading and for any suggestions.
Our Pirellis are 11/32 tread depth with 740 tread wear rating.
- 3751 Views
Last post by Chai
- 11 Replies
- 3324 Views
Last post by Pretribrapper
- 3279 Views
Last post by SuperHerman
- 1738 Views
Last post by xHeart
- 12 Replies
- 9884 Views
Last post by Leopold
