Its time to do the rear hubs on our 2008 V70 3.2 FWD, 150,xxx +/- on the clock.
I've done volvo front hubs before (not on this particular vehicle), and the rears seem to just bolt in using 4 Torx bolts.
Is there at tutorial available? I have searched and not found one, though I have not looked for one for the S80. Also, if anyone has done this, any clue on the Torx size?
From what I can tell access to the 4 Torx and ABS sensor will be via extensions (after lots of PB Blaster) and while appears fairly straight forward I want to know what I am up against.
Any helpful advice is greatly appreciated!
2008 Volvo V70 3.2 FWD Rear Hub replacement
volvooh
- Year and Model: '98 S70, '05&'08 V70
- Been thanked: 4 times
Yikes- just read a post on a V50??? with similar torx mounting. Looks like I may be cutting this off and the dust cover too??? Has anyone successfully removed the Torx from the rear?
volvooh
Thanks- it looked straight forward till I saw the rusty torx heads. I have the luxury of a back-up car (always a good thing when all your DD's are over 100k) that I can put into service while I get this repair completed. My plan is to get it multiple applications of heat and PB Blaster over several days and hope that I can get enough bite on the torx to either back them out or break them off. However, I have an angle grinder with cut-off wheels which I will press into service if necessary.
I do not have a manual or a Vida. Probably should invest in one considering between my wife, I and kids I have 5 Volvos sitting in my driveway at any given time.
Its starting to get noisy the usual rumble, grinding sound.
- 2400 Views
Last post by [email protected]
- 1923 Views
- 1897 Views
Last post by Mikaro07
- 1894 Views
- 688 Views
Last post by benpineapple
