98 xc: 4 doors swappable with 850 sedan? Topic is solved
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
today I'm supposed to go pick up a 97 850 GLT at 3 p.m. I want to know if the doors on the 97 850 swappable with 98 XC. looks like it should work but I need confirmation. exact same paint color.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Has thanked: 311 times
- Been thanked: 817 times
The 850 doors will bolt right on the x70 and vice-versa.
The wiring however is different between the two cars.
If you carefully study the wiring schematics for both cars you could figure out which wires to change and how. Otherwise things like door locks and windows won't work properly. E.g. the master window switch in an 850 is in the center console but it's in the driver's door in an x70. I'm not sure I would even plug in the doors without reading up as there is probably some danger of blowing out window motors etc. You could switch the entire dash harness along with the doors that might fix it.
So overall: Not sure - requires a lot of reading of schematics and multimeter work. You could just try and see what happens, you can always go back to the original doors.
You probably already considered this but keep in mind the 850 outside door trim is different, not color matched like on an x70.
- CIK7
love the detailed answer! thank you!erikv11 wrote: 08 Jul 2020, 07:42 The 850 doors will bolt right on the x70 and vice-versa.
- 701 Views
- 19 Replies
- 3362 Views
Last post by 850TurboTurtle
- 472 Views
Last post by phils94850
- 455 Views
Last post by wisewoman
- 399 Views
