control arm bushes replacing without press Topic is solved
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Lower Control Arm bushes replacement.
First of all dont try to use a vice as a press
Vice destroyed by LCA
Both bushes are best cut for removal.
cut out old bushing
cut out old bushing
Buy a decent clamping tool with the correct sized cups, i tried two metal shops and non had the correct size pipe for the job.
clamping tool
clamping tool
I also used a 5Tonne gear puller because it has a longer reach (long legs), it felt like it was at it limit, would suggest a 10Tonne
The large rear bush is easily done, the smaller front bush is a problem only due to its length. Lub it up and slowly press it in. I tried putting the bushing in the freezer and heating up the LCA with a heat gun but it didnt seem effective
lca press 2
lca press 2
Installing the LCA by removing strut bolts and jacking up hub.
install lca
install lca
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
- I admire you for doing this.
- Most people just get a new control arm for a little more money. Less headache.
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
Congratulations, the front one is what discouraged me from doing this job. I went with Lemforder arms, and what I've read about them here, I might be tackling this again sooner then later. Nice job, good info.
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Congrats! One interesting detail is you have the XC70 arms - you notice behind the front bushing the surface is flat so pretty easy to place the adapter. On the S60/V70/S80 this same surface makes an angle, pretty annoying. I think one of the key to success is to render the CA hole as smooth as possible, this reduces the friction coefficient when pressing the busing in.
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Harbor Freight 12-ton bottle jack press was $100 or so, and sure thing can press the bushing out and in :) I did 3 sets of LCAs, both flat from XC70 and curved from V70. For curved I didn't use any adapters, traction provided by wise grip was enough.
Next time I would get a new LCA, but Volvo originals are way too expensive, and I developed a distrust in Lemforder since they moved parts production for our platform to countries with less rigorous QA.
In fact, the next time I will get XC90 LCAs :)
Has thanked: 1610 times
Been thanked: 4065 times
Where can you source the bushings from?
Part numbers are nice, too!
vtl
Post by vtl »
FCP -> your car -> Suspension -> Control Arms and Bushings?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Thanks Darryl. This is much better than what I tried. :lol:
I made your account MVS Contributor for sharing this. Let me know if you want the contributor avatar.
Also -> Amazon link
oragex
Post by oragex »
If one can press - or have the bushings pressed - definitely go with genuine bushings from Volvo. The bushings run for $70 for each side - so under $150 for both arms and you know you have genuine, no more worries. I've been there trying control arms (and struts) and ended with genuine bushings. As vtl says, I'm loosing trust in some Lemforder parts - such as their individually sold bushings, I even put their bushing for XC90 and it lasted 1 year.
If you want genuine, these are the parts for my S60 as example - each side runs for $60 USD - see the two very last items at the bottom of the list
https://www.volvopartswebstore.com/show ... evel=24659
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
matthew1 wrote: 10 Jul 2020, 13:19 Thanks Darryl. This is much better than what I tried. :lol:
home ovens don't get hot enough for that press fit.
when they fit steel tires to cast iron steam loco wheels they get them very hot with direct flame, they're a shrink fit.
At the high temps needed, I wonder if the rubber inserts can sustain the heat.
Maybe go halfway with heat and dry ice for the insert.
One day I'll get a real press.
I have a small one, good for pressing blueberries maybe.
