Black or Green coolant tank cap? Topic is solved
Has thanked: 2210 times
Been thanked: 1852 times
Senility has set in!!
Which is the correct cap to use? I know that either green or black is recommended but which one?
I am being optimistic in hoping the reason it looks like coolant has escaped passed the green cap is it is bad. However, I think that is a relatively recent Volvo part install so hoping it is not the head gasket following the overheating a couple of years ago when the radiator hose broke off in rush hour traffic.
Thanks,
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Mine is somehow gray and it's still original.
Somebody on the forum long time ago said that "they are born bad"....but i never had a problem with it.
Green is a replacement as far as i remember.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Thanks Misha.
I thought that there was a belief that either black or green was not good to use or they had different pressure values. Maybe I am just imagining it?
misha
Post by misha »
I was referring on gray one when someone said that they are born bad.
It seems that someones experience is that grey one should be replaced with green.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
befarrer
Year and Model: 1998 V70 AWD
Has thanked: 1 time
Been thanked: 24 times
Post by befarrer »
I'm using a blue one. It's only like 8lbs or 12lbs or something like that. But green is the correct one.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
