rebuild or replace engine: opinions? please recommend online engine shop
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
I am looking around at used engines for a 2.3L top of line. know any reliable online engine companies? would y'all recommend rebuilding my 2.4 or buying new engine? seems like $1000-1500 is the price for the rebuilt ones.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- Been thanked: 4064 times
Used engine with junkyard warranty should be about $500
- CIK7
I found a few rebuilt engines on SWengines.com. the factory 2.4 for my XC is $1,095 and the 2.3 for the R AWD is $1,495 w/ 5yr/50k Mile warranty. I wonder if it would be cheaper for me to rebuild my own engine. I probably would be going for performance increase from 190hp factory to 275hp aftermarket. I am thinking that I will not ditch the angle gear but will remove the drive shaft for increased gas mileage. I assume the angle gear even with drive shaft removed still adds friction?
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
If this car is just going to be your "back-up car", grab a used JY 2.4 engine. P2 LPT engines are pretty inexpensive.
We have an '01 LPT motor in the wife's '97 GLT. Had 145K on it, which is half of what her old one did.
- Has thanked: 2197 times
- Been thanked: 1851 times
Not sure what you are getting for those prices on the SW rebuilt engines. To just do a head job with valves over haul, gaskets, leveling and anything else head related you are close to $500-600 at least. So what else do they supply with the engine, and what quality of parts do they use? The warranty is fair depending on how good they are at fulfilling it. Do they have good reviews?
Having a reworked engine does have it's advantages with new seals on cams, crank, etc. Either way, used with a junkyard warranty if they go wrong then you have to replace it, so work is the same. It is a tough decision.
I'm assuming you found a major issue with the old engine, i/ don't recall the final outcome from your other thread.
Either way, good luck!
Looking at SWengines web-site I could not see any claim the engines were re-built. Maybe I missed the claim. All the engines appear to be used only which means the difference you are paying them for the engine is paying for a warranty over what a junkyard charges. I guess that is fair.
- RickHaleParker
- Been thanked: 977 times
Do a JY RNC conversion. Gain Graphite coated pistons, Improved cooling, Oil trap integrated into the Oil filter & Cyclonic oil separators.
Active
Past
Past
- CIK7
I think I am just going to buy an engine and get this car going again. Oklahoma sucks in terms of finding ample 850s.Chuck W wrote: 11 Jul 2020, 10:54 If this car is just going to be your "back-up car", grab a used JY 2.4 engine. P2 LPT engines are pretty inexpensive.
- CIK7
I thought I saw a pic somewhere and it looked like they had completely cleaned and rebuilt it. yes my engine hydrolocked, which I think that had something to do with a timing jump. doesn't seem right.scot850 wrote: 11 Jul 2020, 11:14 Not sure what you are getting for those prices on the SW rebuilt engines. To just do a head job with valves over haul, gaskets, leveling and anything else head related you are close to $500-600 at least. So what else do they supply with the engine, and what quality of parts do they use? The warranty is fair depending on how good they are at fulfilling it. Do they have good reviews?
- Chuck W
The RN LPTs are a pretty easy swap, and you get rid of the oil cooler in rad. We just swapped her old intake (The same as your '98).CIK7 wrote: 11 Jul 2020, 15:00I think I am just going to buy an engine and get this car going again. Oklahoma sucks in terms of finding ample 850s.Chuck W wrote: 11 Jul 2020, 10:54 If this car is just going to be your "back-up car", grab a used JY 2.4 engine. P2 LPT engines are pretty inexpensive.
A couple other bits here and there, but not terrible.
- 3744 Views
Last post by HobbYbboH
- 36 Replies
- 8802 Views
Last post by amblerman
- 17 Replies
- 1936 Views
- 12 Replies
- 16178 Views
Last post by maggs
- 1235 Views
Last post by lincolnshibuya
