C70 (B5204T3) trouble starting and rough runing Topic is solved
slklite
Year and Model: 1999 C70
Post by slklite »
Hello guys and vals :lol:
I own a C70 from 1999 (ME7), and it's been tuning good for the last 2 years.
Yesterday i changed the front hub bearing assemblé, and After that car wouldn't start. The starting problem did happen before. No cela or fault code ...
If i insist a lot (more than 30sec cranking) it starts to cough and then engine comes back from the dead... But once it starts, i can hear it tuning rough. Exhaust smell is bad and a lot of backfire...
I scanned it for fault codes, and nothing !!!
The few times it hapenned before, once it starts, just have to turn it off and back on again, and all it's all back to normal.
But this time, it wouldn't run normally...
I'm suspecting the crankshaft sensor, as when i crank, the rev counter barely moves...
Do you have any ideas ?
Thanks.
Has thanked: 1610 times
Been thanked: 4068 times
More likely to be a throttle body problem. How old is the throttle body?
slklite
Post by slklite »
I don't know.
According to measured values, it looks to be moving properly.
Is there a way to check for sure ?
2000c70hpt
Year and Model: 2000 C70
Has thanked: 1 time
Been thanked: 8 times
Post by 2000c70hpt »
My c70 does the same if I let it sit. Narrowed it down to the fuel pump. Can’t hold pressure in the line when it sits for a few days so it’s really hard to start. Try there.
2000 C70 hpt with 140k
2008 xc90 t6 non turbo with 170k
slklite
Post by slklite »
All right, good. You might be right as i saw that the fuel pressure wasn't very high when i checked the "check valve"
Another thing is that spark seems quite weak
I'll try to take a video to show these problems.
Thanks for your insight.
2000c70hpt
Has thanked: 1 time
Spark was always weak looking on mine. so i figured it to be normal. With a good fuel pump though he fires right up
slklite
Post by slklite »
I remember cranking with injectors out of the intake port and they seemed to be giving enough fuel, but i might be wrong...
