Will this tool work for removing power steering pulley?
sventastic
Year and Model: 1996 854R
Been thanked: 6 times
Post by sventastic »
I'm wondering if this tool - https://www.partsource.ca/products/7703 ... -installer will work for removing my power steering pulley. I can rent it at a local store but I won't be able to check it out for another 5 hours until I'm off work. Just wondering if I should start looking elsewhere as I'm trying to get this job done by Thursday for a road trip.
I think it will be fine as long as the threads match up, but it's meant for Ford/GM so it's likely imperial. I'll bring the pump with me to the store to check the threads before renting.
I've seen the Lisle 39000 has been used with success, and it appears to be intended for domestic models as well, so I might be in luck?
https://www.lislecorp.com/specialty-too ... ley-puller
1996 854R | M56H | 16T | 274k | BC, Canada
sventastic
I can now confirm that this tool does not work for removing the pulley... The collar for the puller is ever so slightly too large, it slipped and chewed up the lip on the pulley...
Has thanked: 2197 times
Been thanked: 1851 times
Yikes! :o :o
sventastic
The tool used for reinstalling the pulley did work perfectly however!
I used a 3 jaw puller to get the pulley off, worked brilliantly.
