Does anyone know what was the original grille used on a 2000 C70 Convertible and was it used on other Volvo models as well?
I want to replace the one on our C70,it is beat up looking.When I look for one it's kind of confusing because it pulls up the one with the black plastic honey comb style squares behind it instead of the chrome one with vertical bars, and trying to find the Volvo badge for it is confusing as well.
Front grille question
- subzerocarfanatic
- Year and Model: 2000 Volvo C70 HT
- Has thanked: 75 times
- Been thanked: 10 times
yanga001
- Has thanked: 62 times
- Been thanked: 115 times
Original C70 was likely the waterfall grille or shiny one. They are fairly cheap as far as i know. If you want to be true to 2000 then you can grab one with a blue logo. Alternatively, if your logo is in good condition, then you can cut off the tabs behind it and move it over to an older 98 grille. The swap is very easy to do.
Part No: 9127580
Part No: 9127580
2008 S60 2.5T Auto (Sold)
- subzerocarfanatic
The part # you referenced,is that the grille or the badge?yanga001 wrote: 16 Jul 2020, 08:53 Original C70 was likely the waterfall grille or shiny one. They are fairly cheap as far as i know. If you want to be true to 2000 then you can grab one with a blue logo. Alternatively, if your logo is in good condition, then you can cut off the tabs behind it and move it over to an older 98 grille. The swap is very easy to do.
Part No: 9127580
yanga001
grille
yanga001
Forgot to mention, all grilles will fit all of the p80's so do not limit yourself to just a C70 one. You can pick a v70 or s70 as well.
You can verify this on here:
https://www.volvopartswebstore.com/prod ... 27580.html
- subzerocarfanatic
I went to oemvolvopartsonline.com and it says this part does not fit your car then showed the one that they say does fit, which is part # 9190777. ??
yanga001
Do you have the 2.3T? If so then the egg crate one (number you posted) is the period and type correct one for your car i believe. You can find those on XC70's of the period and they are not as susceptible to fading as the plastic itself is coloured.
The grilles are universal fit so if you just want to put one in, then you can use either part number, and any of the p80 years
- subzerocarfanatic
Yes,mine is the 2.3 Turbo Convertible.
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
Keep in mind, the ‘98 had the older black “square” logo like 850’s.
‘99-‘00 got the newer blue badge that’s a slighty different shape.
- subzerocarfanatic
Yeah, I found an older 96 version with the black badge, I think I like the newer ones, they are expensive to replace though worth it I suppose.I found a new OEM grille,just the chrome part with no badges or anything for $39 but then I have to purchase the clips, post, and new Volvo badge which is around $55- $60 itself.BEJinFbk wrote: 16 Jul 2020, 10:31 Keep in mind, the ‘98 had the older black “square” logo like 850’s.
- 6764 Views
Last post by ashyu
- 2485 Views
Last post by RickHaleParker
- 1763 Views
Last post by MILLSY
- 1603 Views
Last post by Sommerfeldt
- 1316 Views
Last post by JRL
