Do these sounds portend sudden failure?
It was off the road for nearly 2 years and I only heard it for the first time shortly after getting it back on the road. Just made a run into town and back and did not hear it at all.
Is there a remedy to prolong the life of these?
ON my mid 80s Mercedes I was able to "patch up" deeply crazed rubber boots with quality silicon sealant and add lube too . Seems to have been worth the effort.
occasional brief clicking from wheels, CV joints??
- alschnertz
- Year and Model: 1995 854T
- Has thanked: 2 times
- Been thanked: 12 times
Your title refers to "brief clicking from wheels".Rocket99 wrote: 19 Jul 2020, 08:14 Do these sounds portend sudden failure?
Yet your post states that you "did not hear it at all".
Can't speak for others, but I'm not sure what you're asking.
It may be better to provide more information about what is actually happening.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- alschnertz
I did. Your description of symptoms lacks detail.
You didn't describe anything other than you "heard it for a short time shortly..."
Followed by you then "did not hear it at all".
What were the conditions when you ;"heard it for a short time shortly"?
And no, there is no way to prolong their life. Once they're clicking, they're shot.
'84 Prelude
'06 MPV
'13 Ford Focus SE
'84 Prelude
'06 MPV
'13 Ford Focus SE
- Has thanked: 2205 times
Do you get more clicking when turning? What condition are the CV boots? I read your note on the adding silicon to the boots.
Do you know if these are the original CV axles? If they are original Volvo then they are worth re-booting and adding fresh grease to.
Are you still getting the clicking having driven the car for a bit? When you got the car back on the road, did you do any work on the brakes? If so you may have just bent the brake backing plates enough to rub. Gentle massaging of the back plates may be enough to sort that if that is the issue.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Also, if the car sat for a prolonged period, the grease in the CVs may have settled. Once you started driving, it got warmed up and slung/flowed to where it needs to be. Just like "square" tires do after you start driving.
Current Volvos:
Rocket99
- Year and Model: 2000 V70 XC
- Has thanked: 56 times
Neil thanks for these comments and suggestions. Not increased while turning but may be decreasing after driving for several days.scot850 wrote: 19 Jul 2020, 14:33 Do you get more clicking when turning? What condition are the CV boots? I read your note on the adding silicon to the boots.
I do need to Jack 'er way up and get under to look at the boots. This V70 is low to the ground making it necessary to lift it quite a bit to get under there..
Do not have any history, got this car from younger brother when he passed in '17. Now that its back on the road and stable in the coolant department I can appreciate why people like these Volvos so much. it really is nice. I think it weighs about the same as my MB 300TD but feels light and nimble , big time, compared to the MB. That MB is a heavy diesel engine that is sluggish until, and also after, fully warm.
thx again
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
If the boot(s) are leaking already add some grease using a grease gun and needle. Have been nursing two axles for going on two years. Neither are clicking but do make a mess if I put too much grease. Insert at end of boot as close to the bearing as possible and make sure the needle is in the bearing. Insert 180 from each insertion point no more. You'll be amazed how far that can take you if you can't get to it right away.Rocket99 wrote: 19 Jul 2020, 08:14 Do these sounds portend sudden failure?
https://www.amazon.com/FIXSMITH-Grease- ... 20&sr=8-13
- 67 Replies
- 12252 Views
Last post by clifford06
- 1334 Views
Last post by misha
- 1653 Views
- 8939 Views
Last post by cn90
- 27 Replies
- 6191 Views
Last post by hu5ker555
