2002 XC70 Clicking! Passenger side [loose control arm] Topic is solved
nyurch
Year and Model: '98 S70GLT '02V70X/C
Post by nyurch »
if i ever needed help, now is the time :?
02 v70xc
I have a terrible loud clicking when my car is parked and I turn the wheels. Cv joint right? No. In the past 4 weeks total i have replaced the following:
2 sets of axles on each side. Cardone
Both stabilizers. Moog
Both strut assemblies. Forget the brand.
Ball joints. Moog
New tires all around.
I'm at a loss. Strut seats are tight, everything is tight and torqued. Car runs and drives fine if not great, smooth ride.
Throw me your thoughts before I crush simply from frustration. The click is embarrassing and I can see the 'she needs new axles' look on people's faces. Tia
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
My kingdom for a 4 post lift.
Lacking that, you need a safe method to get under there and put your hands on the usual suspects whilst someone turns the wheel.
I'm thinking ramps, then jack the car just enough to put jackstands under the subframe plates. Lower car on the jackstands.
The ramps will keep the suspension sprung rather than having the wheels hanging down out of normal configuration.
Find it by feel.
nyurch
Post by nyurch »
There is no click when its on a lift!
The click feels like it is coming from the hub hence the ball joint replacement, the ball joint i replaced in January failed and needed to be replaced anyway. It is a very prominent click and you can feel it through the whole suspension as well. Is there a chance it could actually be the hub?
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 112 times
Post by E Showell »
Sway bar end links bad?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
nyurch
Post by nyurch »
I called them stabilizers, brand new.
Is it possible that I went through 2 bad reman axles?? Driver side seems okay.
E Showell
Post by E Showell »
I learned long ago to go Volvo only on sway bar end links.
'95 855 auto (sold)
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Is that a single loud click ? Does it repeat as the wheel is turned ? Was it there before replacing the strut assy ? Does it do it if you turn the wheels with the engine off and key in POS II (harder to turn)
nyurch
Post by nyurch »
Single loud click, its also doing it when coming to a complete stop. Sometimes there is two clicks but never repetitive. I can get a repeat click with turning the wheel right in a certain spot and go back and forth with the wheel.
Was there before strut assembly, my struts were junk so figured while I was in there, might as well change them.
Still clicks when engine is off.
oragex
Post by oragex »
Does it happen when the steering is at full lock ? Or at some random steering angle ? Many miles ?
nyurch
Post by nyurch »
Not full lock but close. I would like to try to get a video of it. 199k
