Hidden rust - rear seat mounts under arch liners
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
There is a hidden rust spot on these P80s that I've only just recently been made aware of, thanks to this post on a UK forum - link. It seems this affects a significant number of P80s, but is largerly un-noticed due to its location. Eventually it will result in an MOT failure in the UK as the rust appears to be localised around the rear seat mount.
Below are pictures showing the rust my car presented with, I got lucky and it only required wire-wheeling and undersealing. Bear in mind my car has never lived near an ocean, and being in the UK we do not get harsh winters, so there has been minimal salt present. Despite this, all 850s I've come across on that forum have had the same rust or worse.
With the arch liner off, here is the rust I am highlighting:
In my case I could get away with wire-wheeling, and using a flap-disc to get to this position:
From this point I was able to apply rust convertor (Bilt Hamber Hydrate80 is the best on the market, and reasonably priced, if you can get your hands onit) and a coat of Dinitrol 4941 underbody.
Image4941 applied
Excluding time taken for paint to dry both sides took me around 2 hours, with a materials cost of £30 (Bilt Hamber Hydrate80 and one 500mL can of Dinitrol 4941 - the latter will be sufficient to do both arches, and everything behind the rear bumper with plenty to spare). The added bonus is there is a small reduction in NVH thanks to the underseal on the arches.
For the time and small cost investment I would certainly recommend you take a look under there - it could potentially save you a big headache down the line.
Cookeh
Post by Cookeh »
As a reference how quickly this can become an issue, this next photo was taken around 11 months ago, and we had an especially mild winter this year with no grit being applied.
amblerman
Year and Model: 1999 s70
Has thanked: 2 times
Been thanked: 70 times
Post by amblerman »
Wow.. thanks for the notes on this. I have been so impressed with Volvo's rust protection that I wouldn't even bothered looking there.
Just to be clear, jack up rear, remove wheel, remove plastic liner and inspect. Correct? The reason people don't notice this until it's too late is it's hidden by plastic wheel liner correct?
Cookeh
Post by Cookeh »
Exactly, yes - on both points.
Has thanked: 1610 times
Been thanked: 4065 times
I’m inspecting mine really closely, I’ve heard this can spread to the rocker panels
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
:mrgreen: :mrgreen: :mrgreen:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
misha
Post by misha »
Cookeh wrote: 21 Jul 2020, 08:45 ...Eventually it will result in an MOT failure in the UK as the rust appears to be localised around the rear seat mount.
Why would MOT test require arch liners to be removed?
It's funny...because sills(rocker panels) are covered with plastic side skirts.Do they remove them too to inspect sills condition for MOT testing?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
They probably see bubbling on the inside.
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
You just answered a question of mine on another thread.... :)
1999 V70 GLT
Cookeh
Post by Cookeh »
misha wrote: 21 Jul 2020, 15:54
They inspect seat belt anchorage points and seat mounts as part of the test. In this instance, as abscate rightly pointed out, they'd see bubbling and investigate further. You can also just about notice rust peeking out beneath the arch liners (even on mine, which is relatively clean compared to other cars).
Sill covers are generally not removed, unless as above, they are given reason to investigate - such as rust patches or bubbles close to that area.
The test is a bit weird, nothing can strictly be removed from the car, so you can 'hide' a lot of issues with covers. However, if they notice something relating to structural rust or rust around mounting points then they can investigate further in order to show you what needs to be fixed.
