2007 xc90 v8 serpentine belt replacement help
Pretribrapper
- Year and Model: 2011 C30 2.0 T5
- Has thanked: 59 times
- Been thanked: 9 times
Hoping someone can give me some direction. Had an idler pulley go bad and serpantine belt broke. I replaced pulley but cannot get new belt on. I have tensioner as far as I believe I can get it to go and I seem to be about 1 inch short of being able to slide new belt over the final pulley. Is it possible belt is too short. Item number on belt matches part number I need for car...
Pretribrapper
Belt was an aftermarket 990K6 from Rock Auto. I am trying a different belt but not sure that is the issue....
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
May try compare the new belt with the broken one, otherwise look at each pulley to make sure the belt sits correctly centered on the pulley
Masscomguru
- Year and Model: 2010 XC90 V8
- Been thanked: 16 times
When I did mine, it kept getting hung up near the crank pulley, I had to remove the wheel and fit it there first. It’s easy for it to “feel” ok if not on correctly.
- 2000c70hpt
- Year and Model: 2000 C70
- Has thanked: 1 time
- Been thanked: 8 times
The 5 cylinder belts are cake compared to the 3.2. Took me almost 3 hours to do mine on my 3.2. 10 minutes on my 2.3
2000 C70 hpt with 140k
2008 xc90 t6 non turbo with 170k
- 20 Replies
- 17369 Views
Last post by Hurtfeelings
- 22 Replies
- 35780 Views
Last post by erikv11
- 31 Replies
- 3932 Views
Last post by cn90
- 21 Replies
- 5293 Views
Last post by viper69
- 62 Replies
- 17759 Views
Last post by Shanestrait
