How to remove clearcoat without repainting? Topic is solved
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
I have multiple cars with peeling clear coat and it bugs me. But not near enough to pony up for a repaint job. Does anyone have a solution?
Has thanked: 1611 times
Been thanked: 4072 times
My kids tried a snow shovel with a metal edge, which was effective at removing it in lines,but might not be th effect you are looking for,
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
You don't need to remove the old clear coat. Just work the old clear coat with 1500 - 2500 grit wet & dry in wet mode or Scotch Brite to smooth the old clear coat. Watch what you are doing so you don't cut into the paint layer. Use your finger tips to feel the clear coat, stop when it feels smooth. Then shoot a new clear coat over the old clear coat. If you are just doing patches make sure you blend it into the old so you don't get transition lines.
Active
Past
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
volvolugnut wrote: 22 Jul 2020, 17:45 I have multiple cars with peeling clear coat and it bugs me. But not near enough to pony up for a repaint job. Does anyone have a solution?
There is a difference between checking and peeling.
1) Use a power washer to peel off loose outer edges of the clear as much as possible.
2) Sand the edges to blend with the paint careful not remove the paint.
3) Either apply a clear in missing area blending with old clear.
4) Or just apply your favorite protectant.
abscate wrote: 22 Jul 2020, 18:13 My kids tried a snow shovel with a metal edge, which was effective at removing it in lines,but might not be th effect you are looking for,
I accepted your answer as the best. Fast, easy and I already have a snow shovel. Can I borrow your kids?
