We need 1 FR strut assembly for a 2001 S60 FWD for a Volvo owner in need. New or working/used condition. He drives his wife 60 miles 3x/week for cancer treatment. I'll pay your shipping costs.
Did you know? 🤔
XC90 transmission cooler on S80?
Help, Advice, Owners' Discussion and DIY Tutorials on the Volvo S80 model. Sometimes called an "executive car", the S80 was and continues to be Volvo's top-of-the-line passenger car.
SlowLane
Year and Model: 1996 855 Turbo
Has thanked: 0
United States of America
SlowLane
Post by SlowLane » Thu Jul 23, 2020 4:03 pm
Anyone tried adapting the external transmission cooler from an XC90 to an S80? I figure those would be more plentiful at the Pick'n'Pull than the native S80 external cooler.
The drawings seem to show that they are similar but different in the area of the hose connections at the cooler, but perhaps the XC90 one is "close enough" to work.
Current Volvos:
2002 2.9 S80 - Wife's car, the "Silver Flash"
1996 855 Turbo - Formerly daughter's ride. My toy now.
Former Volvos:
1997 855 GLT - Totalled by daughter. Now she appreciates Volvos. :wink:
1984 244 DL B23F - warped head after radiator blew
1982 245 GL B21A - My first Volvo. Sold with 400,000 km on it.
Other:
1981 VW Westfalia
bronco
Year and Model: 1998 V70
Has thanked: 6 times
Been thanked: 16 times
bronco
Re: XC90 transmission cooler on S80?
Post by bronco » Thu Jul 23, 2020 8:35 pm
What if there is gunk in it? pencil shavings or bird lime? Ok friction material etc from the transmission it was last attached to?
Friends don't let friends reuse transmission coolers . That is originally a Ford rule(E4OD) but it applies to every brand equally
MoVolvos
Year and Model: 03S80T6~08C30T5
Has thanked: 34 times
Been thanked: 76 times
MoVolvos
Post by MoVolvos » Fri Jul 24, 2020 1:08 pm
The only thing I would not recommend is adding an additional half a quart each time you refill if the level was correct to begin with.
Volvo XC90 V8 TF-80SC OEM Transmission Cooler Install / Flush
1998 S70 T5 - Donated
2003 S80 T6
2003 GS300
2003 Odyssey
2008 C30 T5
2019 Atlas SE 4 Motion
SlowLane
Has thanked: 0
SlowLane
Post by SlowLane » Fri Jul 24, 2020 11:40 pm
Kooler Kleen! (okay, get past the deliberately egregious spelling. You'd almost think it was a Stan Lee character)
Current Volvos:
Former Volvos:
Other:
1981 VW Westfalia
SuperHerman
Has thanked: 0
Been thanked: 160 times
SuperHerman
Post by SuperHerman » Sat Jul 25, 2020 12:33 am
Generic oil coolers are cheap enough - come with all the fittings.
Out of curiosity, why do you want to add an oil cooler? Does the wife use the Silver Flash for towing?
bronco
bronco
Post by bronco » Sat Jul 25, 2020 7:07 am
I used to regularly rebuild the early Ford F series 4 speed overdrives The E4OD was an outgrowth of the venerable C6 that had been around for decades. They took the main setup from the C6 and added an overdrive . It took them 5 years to get the transmission to a point where it was halfway reliable. Pickup transmissions see a lot of hard use and there was a lot of clutch wear and a lot of material wound up going unfiltered to the coolers and plugging the auxiliary and radiator cooler up pretty well. The fluid coming back from the cooler would spray on the planetary gear to cool and lube it. So when the coolers plugged that didn't get lubed and got hot and started to disintegrate and spewed their guts into the cooler and radiator before ceasing to function.
So a lot of guys would need to get a transmission rebuilt and they would put it in and drive off but the old coolers would then either be plugged and fail to lube the new planetary or not be plugged and dump all the grit they contained right into the new transmission.
Now its true that the car in the junkyard may not have had a bad trans but its really never worth finding out the hard way .
never reuse a cooler if the transmission blew up is my rule and never swap a cooler to another vehicle just put a new one on and poke a hole in the old one just in case
SlowLane
Has thanked: 0
SlowLane
Post by SlowLane » Sat Jul 25, 2020 12:51 pm
No, just idle curiosity. Having invested a fair bit of cash and sweat equity in this transmission rebuild, I was thinking of ways to increase the lifespan, and cooler ATF came to mind. But I have no evidence that the old ATF was getting too hot. It came out nicely clear and red, but it wasn't all that old. Think I replaced it about two years ago.
Just thinking of ways to make more work for myself, I guess. Not like I don't have a backlog of projects. The poptop on the Westy needs some TLC.
Thanks to you and bronco for the well-reasoned advice.
Current Volvos:
Former Volvos:
Other:
1981 VW Westfalia
bronco
bronco
Post by bronco » Sat Jul 25, 2020 1:20 pm
