2004 V70R Ignition issue
dmechnic
Year and Model: 2004 V70 R
Has thanked: 3 times
Post by dmechnic »
So i just dropped $6500 getting work done on my “baby” and the wife drove it home (mistake). Ends up it was running rough the whole way & threw P0302 and P2302 codes just as she got home. The guy had told me he used some liquid tape to cover some of the coil wires as they were exposed by the connectors. Ok, not the best way but I get it if it’s just a little bit. I open the hood at home expecting a grounding issue on #2 to find a shit show goop and wires. Ends up the insulation is brittle as can be on the first three cylinders so I unplug those as well as the cam sensors (which were marked) and expose everything and wrap each one individually with electrical tape for temporary patch. Got it all back together, covered & wrapped up, plugged everything in and now it seems I have ZERO ignition. The engine isn’t coughing or even attempting to catch, just cranking. I have not looked for an ignition relay/fuse to see if something popped. It is also not throwing any codes at all, so I’m at a complete loss. Any help would be greatly appreciated.
And am I unfortunately correct in that VOLVO integrates the ignition coil wires into the ENTIRE system harness, requiring me to splice in replacements?? Whose dumb idea was that?!?! You’d think they’d know those heads get pretty hot and destroy those wires over time.
Has thanked: 1611 times
Been thanked: 4072 times
Look for 12 volts on the pinoutson one of the coils to see if you are getting supply voltage. The supply fuse takes out both ignition and a bunch of other stuff on these cars
Fewer than 5% of mechanics can actually wire. It’s a plug and replace job, nowadays
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
Yes, the harness is big and goes all round the engine into the ECM. So it has to be cut - can get the wires on top of the engine from a junkyard quite easily in good condition assuming it's from car with same VVT solenoids. Not all cars get these wires damaged from heat, so pretty easy find at the junkyard
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
oragex wrote: 24 Jul 2020, 05:06 Not all cars get these wires damaged from heat, so pretty easy find at the junkyard
If one wants new harnesses they can be found at Dave's 240 Turbo.
The 2004 - 2007 S60R/V70R connectors are slightly different. But a non-R can be modified to fit.
Active
Past
dmechnic
Post by dmechnic »
So I checked and the fuse was blown, tried a new fuse and it immediately popped so clearly something is shorting out. Stripped everything and there are a couple places that I’m highly suspect of. Going to look into shrink tubing supplies in a roll and try to pull each pin and sheath them all the way back. Gotta YouTube how to pull the pins now.
dmechnic
Post by dmechnic »
Ordered new plugs with 24” whips and will be splicing/rewiring the 5 plugs. Also adding shrink wrap to the wires running from the main harness line to help protect and maintain them
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Use a small nail to pull the pins, ive replaced a few broken connectors on mine
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
dmechnic
Post by dmechnic »
New plugs with fresh wiring is in...now come to find there is a P0234 code, there is next to no boost, and the speed sensitive steering isn’t functioning properly. Glad I spent $6500 ($7500 but talked him down $1k) to have it fixed right by a Volvo specialist.
jonesg
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
P0234 code is overboost, check the linkage on the wastegate.
Test the wastegate function, pull the tiny hairpin retainer and actuate the wastegate by hand.
jonesg
Post by jonesg »
