v70 engine hunting ( varying rpms ) Topic is solved
pauluscamperman
Year and Model: 2003 v70
Has thanked: 7 times
Post by pauluscamperman »
Hi my son has a 2001 v70 2.4 petrol N/A.
we've just replaced front suspension, on restarting engine runs as normal until brake leaver is depressed then the engine starts to hunt getting progressively worse until engine stalls. can't find any obvious vacuum leaks. any ideas?
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 534 times
Post by jonesg »
pauluscamperman wrote: 24 Jul 2020, 11:07 Hi my son has a 2001 v70 2.4 petrol N/A.
On mine the vacuum is assisted by a pump that I can hear cycling on off as I start down the driveway, just a quiet hum on and off.
Its barely louder than the fuel pump. You probably wouldn't notice if it wasn't cycling by ear, but it would steal vacuum at startup..
Does it go away once the engine warms up.?
pauluscamperman
Hi, the problem remains at all engine temps
jonesg
Post by jonesg »
pauluscamperman wrote: 24 Jul 2020, 15:17 Hi, the problem remains at all engine temps
Smoke test the vac system.
see robert diy youtube video for diy smoke tester.
pauluscamperman
HI Vac system is sound with no leaks, but seem to have resolved issue as car threw an O2 sensor code, I can't explain why the code did not come up sooner but car is now back to normal
Has thanked: 1613 times
Been thanked: 4078 times
Added to title to help those wondering how Volvo engines can run and hide
