Interior dome light
patcal
Year and Model: 1998 S70 GLT
Has thanked: 99 times
Been thanked: 10 times
Post by patcal »
Sort of a different problem concerning the interior lights. I have read a lot about the lock micro switches. What is happening is the upper dome & side interior light are staying on. When I tested the door lock switches the door red lights go off when the door is closed. I have to turn the dome switch to off to turn off the lights. Is there something else controlling just the overhead lights? Thanks.
Pat Callaghan Jr.
98 S70 GLT
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
They should turn off immediatelly after the car is locked.
Otherwise...they turns off after a minute or so.
There should be three positions of the switch...always off,on/off with doors opened or closed and always on.
Check if switch is in proper position.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
patcal
Post by patcal »
My understanding is they fade out after the car is started also. Mine stay on unless I turn the switch to off. I am thinking maybe the switch is flaky.
Pat Callaghan Jr.
98 S70 GLT
misha
Post by misha »
When they are on when you unlock the doors,they should go off after a minute or so or immediatelly after you turn the key to pos.II.
There is a timer relay which controls those lights,but i don't know where it's located.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Has thanked: 1609 times
Been thanked: 4064 times
Sit down with a good drink before you read this one
viewtopic.php?f=1&t=88623&hilit=evita+dome+light
patcal
Post by patcal »
abscate wrote: 26 Jul 2020, 12:19 Sit down with a good drink before you read this one
Thanks. I already printed up the the wire info. Just gotta get that drink.
Pat Callaghan Jr.
98 S70 GLT
patcal
Post by patcal »
Just as a follow up, replaced the switch with no success. Dome light will still stay on. All other lights act as they are supposed to. The thing i sit does not always do it. It will work fine for awhile then all of a sudden i notice the light on when I am driving or the car is locked. Not really sure where to look.
Pat Callaghan Jr.
98 S70 GLT
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
IIRC, the red door lights and the domelight system have separate switches.
BEJinFbk
Post by BEJinFbk »
patcal
Post by patcal »
That make sense since my door lights work fine.
Pat Callaghan Jr.
98 S70 GLT
