2000 V70 not holding fuel pressure
tombrisk
Year and Model: 2000 V70XC AWD
Has thanked: 5 times
Post by tombrisk »
Usually have to crank 3-6 seconds
New: fuel filter 200 miles ago
Vid shows 52ish running, several on/off cycles up to maybe 30ish with several tries
Then bleeds off
Q: What's the most likely cause/fix?
The long crank is my concern
Thanks!
Oops- can't attach .mp4
1st On: 12psi
2nd: 32psi
3rd: 42psi
Start: 52ish, slight fluctuation
kklepack
Year and Model: 2016 XC60
Has thanked: 12 times
Been thanked: 5 times
Post by kklepack »
Sounds like fuel pump is failing. I has same symptoms on my v70.
Has thanked: 1609 times
Been thanked: 4065 times
Oooof. The fuel pump replacment on the p80 AWD line isn’t .........fun.
tombrisk
Post by tombrisk »
Yeah, dang
One (tiring, messy) search result mentioned a non-return valve.
Thoughts?
https://www.amazon.com/SUR-Auto-Parts-S ... svolvo3-20
kklepack
Post by kklepack »
Here is the link to my repair i did with Robert DIY on my 1999 V70R.
Hope helps.
