OIL pressure sensor icon at startup
darrylrobert
Year and Model: 2001 v70xc M58
Been thanked: 27 times
Post by darrylrobert »
Oil is extremely important in an engine, i found that out recently when i cracked my sump.
Before you start your car always check that the oil can icon is there because if its not your sensor is stuck open or if the wire it broken and you basically have no oil warnings and no warnings the circuit is open. No fault codes on VIDA either.
Maybe the car needs to be run for some distance before the ECU detects a problem like a loose wire or sensor stuck open?
dash icons
dash icons
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
ignatz
Year and Model: 2006 S60 t5m
Has thanked: 18 times
Been thanked: 33 times
Post by ignatz »
A lady at work years back would say to me, Hey Rob, there's a gravy boat lit up on my dashboard. What does that mean?
We laughed a bit and then I would add oil to her little Mitsubishi.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
darrylrobert
Funny, so a little Mitsubishi has an oil level sensor and a Volvo doesnt, i did notice that my car has an "optional" level sensor sump pan. I was considering adding that but was easier just to replace with my spare standard sump. I wonder which cars or markets got both oil pressure and level sensor probably the R model and are they wired to the same oil can icon....
I think Volvo engineers/designers have neglected the importance of oil in the engine, i realise its NOT an aircraft but its basically one (unmonitored) wire. In comparison pull a wire or fit a LED bulb to your overhead courtesy light and you will get an error code, ive got error codes for my side mirrors "folding motor missing" , do i need to call a tow truck if my interior light needs changing or mirror dont fold..yet if the pressure sensor is stuck open or wire damaged there are no error codes.
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
All the R models had the fancy oil pan. I’m not sure on the T5’s, though.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
We are in 2020 and we should be thankful that our old cars have a dipstick, so we can check the oil level every time the gas tank is filled, as instructed in owner's manual ;)
What I can really complain about is a coolant temperature gauge that keeps sitting at center even when expansion tank is boiling.
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
My T5 just has the standard oil pressure icon, no oil level sensor. I don't recall an option for the level sensor when I special ordered my car in 2001. Newer model years maybe, but I'd bet it was only available on the R models.
vtl
Post by vtl »
VIDA has CAN-bus query in its SQL database for the oil level sensor for P2. Some cars might have it.
