P80 turbo Valves, trw vs Volvo
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
I am thinking worst case scenarios, that I might need a valve or two when I pull the head on Sveedy. Checking prices I see a huge difference between OEM Volvo and TRW. Like $ 95. for Volvo and $ 17. for TRW. Are these something that needs to be Volvo ? I have used TRW internals on other cars with out issue but I thought I should Check.
1999 V70 GLT
Has thanked: 1610 times
Been thanked: 4068 times
I think the Volvo ones are sodium filled and the TRW are not. Okay for intake
For exhaust, I think you know the answer
bronco
Year and Model: 1998 V70
Has thanked: 49 times
Been thanked: 24 times
Post by bronco »
Ford specc'ed sodium filled valves for the 427 SOHC back in 1965 ! actually I think the intakes were hollow , it said more about the state of valve spring tech than anything else though
I think a decent valve job, a proper seat cut to transfer the heat would make the sodium un-needed
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Get any needed sodium-filled valve-or-two from a junkyard head, spend the money on good seals instead.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
erikv11 wrote: 30 Jul 2020, 22:55 Get any needed sodium-filled valve-or-two from a junkyard head, spend the money on good seals instead.
+1, only thing that changed was stem diameter, 6 vs 7 mm sometime in the conversion to RN and solid lifter period. LPT vs HPT does not matter.
Current Volvos:
