These are originally for the S60 and have slightly different offset than the Columba that is currently on my 850. +1" wider, +7mm greater offset. My rough calculations is about +3/4" on the inward side, +1/2" on the outward side, compared to my Columbas. Otherwise should fit (same pattern and hub size)
Has anyone else put these on a 850 and experienced rubbing? good fit?
Tethys 17" rims on to an 850 (17 spoke)
- echosierra
- Year and Model: 1995 855T
- Has thanked: 1 time
1995 855 Turbo
- misha
- Has thanked: 155 times
- Been thanked: 432 times
ET 50?
Nope!
ET 49 is the highest offset which can fit 850 and NOT wider than 205 tyre with this ET.
No problem if you install spacers.
Nope!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 17784 Views
Last post by tabormeister
- 1227 Views
Last post by WillieEvans
- 1133 Views
- 793 Views
Last post by Juhizz
- 770 Views
Last post by jimmy57
