you know I am the guy who burnt his DIM and now I am using an XC70 2001 DIM which is black but I can drive the car.
thing is.... today I realized from inside I can't open front passenger door.
from outside it's ok. I use the door handle and It moves the door "teeth" or whatever.... but the inside handle does nothing. and it DOESNT FEEL LOOSE.
so I read some topics that it is maybe electrical module thing ... I am worried a lot ....
any suggestion?
S60 2003 passenger door from INSIDE not opening
- darrylrobert
- Year and Model: 2001 v70xc M58
- Been thanked: 27 times
I'm working on a door of my car at the moment fixing a rattle..there are lots of rods/connectors which connect to an electronic module. You have to remove the door skin to see whats going on. It very much sounds like the handle plastic is broken, i believe this is very common. spare parts are available .
1981 260 GLE converted to 240 M46 after auto box failure
1987 740t auto converted to M47
1997 V70t5 auto converted to M56
1998 V70 factory M56 (parts car)
2001 XC70 factory M58
2002 XC70 auto (parts car)
charlitos1988
- Year and Model: s60 2003
I watched a guy who "clip" the broken part with metal around it. is it a valid solution?darrylrobert wrote: 31 Jul 2020, 22:02 I'm working on a door of my car at the moment fixing a rattle..there are lots of rods/connectors which connect to an electronic module. You have to remove the door skin to see whats going on. It very much sounds like the handle plastic is broken, i believe this is very common. spare parts are available .
- darrylrobert
you can try making something but remember that a properly working handle is very important in an emergency.
charlitos1988
last night I finally opened it to look the problem. and seems it was already opened before (2nd hand owner myself), because in the area of the problem, I found that plastic glued and some plastic cable which was holding it....darrylrobert wrote: 02 Aug 2020, 01:01 you can try making something but remember that a properly working handle is very important in an emergency.
so it was just a matter of time it breaks.
well this week I will try to fix it.
- 488 Views
Last post by Stu70
- 1327 Views
Last post by brick_and_motor
- 349 Views
Last post by jonesg
- 579 Views
Last post by V70n Dude
- 1986 Views
Last post by EngineeringBloke
