Hello,
My name is Ronald i'm from The Netherlands and im 25 years old,
Last week i bought an volvo S70 T5 from 1997 with 240 Hp,
Now i was reading all the forums about tuning it with tunerpro RT,
I was wondering if someone has a modded .Bin file for my volvo, its an automatic.
Does someone know where i can find a file ? Ecu number is : 0261204449
best regards,
Does someone have Tuned .Bin file S70 T5?
- Chuck W
- Year and Model: 97 854 T5
- Has thanked: 97 times
- Been thanked: 340 times
How did you plan on using the .bin? That "how to" also shows you how to flash your own .bin. A .bin file alone is useless. It's not like it will magically make it's way your ECU.
You can also try VAST Tuning. He has a couple of options for "canned" tune files.
Someone else's tuned .bin may not be correct for your car, and cause more problems than it's worth.
just put the .bin in using vagcom, you cant just download the .bin from the wiki, if someone can edit it for me i can just put it in ?
Don't understand ur concern? ,i can pay someone who can edit my bin its the 607.bin for the automatic.
- Chuck W
The -607 .bin is right HERE on the Wiki.
You keep saying "edit". For what mods?
Or, you can contact VAST Tuning, you can pay him for whatever file you want.
Azik09
- Year and Model: S70 T5, 1997
- Has thanked: 2 times
- Been thanked: 31 times
In addition. The 449 ECU have an integrated immobiliser function. It is only software function, not hardware. So if you flash your ECU with any other *449 .bin, modded or stock, engine will not start. You have to use 607.bin or solder out flash chip from your ECU, read it with programmer and then edit file.
There are some stock bins without immo (0261204451, for example). If you use such, you will lose immo function and car can be started using just a nail ))
If my English is bad, please correct me
- manovlov
- Year and Model: 1995 850 GLT 2.5 170
- Has thanked: 674 times
- Been thanked: 164 times
Hy Chuck W, Manov here.
I would like to ask you a question. Could you light me about what this forum user want to do ? it seems to matter with the ecu but what for, more Hp ?
Thanks.
Manov
- Chuck W
Hi. Not sure exactly what he wants...manovlov wrote: 07 Aug 2020, 04:53 Hy Chuck W, Manov here.
Thanks.
Manov
- 314 Views
Last post by Slidfungus
- 17 Replies
- 9827 Views
Last post by Yurgan
- 12 Replies
- 2064 Views
Last post by Ac427
- 17 Replies
- 1343 Views
Last post by mar601
- 1038 Views
Last post by RigsPGT
