won't go into 2nd position
- Has thanked: 987 times
- Been thanked: 1075 times
It may be the steering wheel lock mechanism failing. See this post. viewtopic.php?f=9&t=93073&p=533960&hili ... ck#p533773
Many Volvos had this failure after lots of miles and starts. The fix (if you are willing to give up the steering wheel locking feature) is to remove the mechanical lock mechanism in the steering column. This failure seems more common than switch failure.
we changed steering wheel lock mechanism per volvo, cable from shifter to steering wheel, and ignition switch module per volvo, yet still don't show position 2, it's like position 1 is not engaging where 2 should be is showing 1
- 1288 Views
Last post by ducttapeandzipties
- 1369 Views
Last post by RickHaleParker
- 4911 Views
Last post by Oly850
- 59 Replies
- 2200 Views
Last post by CoupeC70
- 13 Replies
- 8354 Views
Last post by woodg
