Help solve the mystery of the relay
bronco
Year and Model: 1998 V70
Has thanked: 49 times
Been thanked: 24 times
Post by bronco »
2002 volvo S80 no brake lights , the top mounted light is fine , fuses fine bulbs fine.
Googling something as simple as a fusebox diagram , map , key , index, whatever you call it seems like it should be simple and yet.............................
the mapping of relays apparently is a more closely guarded secret than the plans of the next stealth fighter!
Is it me or 15 years ago google would have served up pages of results in a micro second?
What mysterious cabal is roaming the internet deleting once widely available information on 18 year old cars?
:roll:
bronco
Post by bronco »
oh i guess I found it , the image is numbered differently than the REM is numbered but its labeled correctly and did the trick
Volvo apparently numbers relays the way GM numbers cylinders (aka wrong)
