2002 s60 check engine light
Dux
Year and Model: 2002 s60
Post by Dux »
Hi,
I cant find the codes or reset the check engine light. I've tried holding the read button and pressing the light (fog?) button. No messages, I've used my obdII reader, it showed no codes (DTC) nor would it reset the light.
It runs like it should, the only issue I have is that I have to refuel very slowly otherwise it gushes fuel back out (another issue I need answered)
What should I try next?
Thanks
- Pete -
Year and Model: 01, 04, 04, 04 V70's
Has thanked: 81 times
Been thanked: 178 times
Post by - Pete - »
Dux wrote: 04 Aug 2020, 13:46 Hi,
Thanks
The trick is to hold the "read" button while simultaneously pressing (twice) the rear fog light button.
There's a valve that prevents fuel from gushing out in the event of a roll-over. I'd be suspicious of this first and foremost.
2001 V70XC 200k
2004 V70 AWD 174k
2004 V70R M66 147k
2004 XC70 361k
1995 F250 7.3PSD 262k
2014 Ram 3500 DRW 116k
93SCMax
Year and Model: 2001 V70 T5 mt
Has thanked: 36 times
Been thanked: 45 times
Post by 93SCMax »
Holding the "READ: button and pushing the rear fog lamp button will only access the message panel and let you know if DTC's were set on specific modules. It will not tell you the specific DTC code.
If your OBDII reader can't reset the check engine light or read any DTC's, you need a better reader or VIDA/DICE.
Lots of posts in the forum about VIDA/DICE.
Good luck.
Dux
Post by Dux »
Updated the obdii software, and now reads codes p0441, p0454, can reset check engine.
thanks for you help
93SCMax
Post by 93SCMax »
Glad you were able to pull the codes.
Both are emissions codes. I'd recommend you tighten or replace your gas cap, reset the codes and then see if they come back.
If you overfilled your tank recently, that also could throw an emissions code.
Good luck.
