I’ve noticed that our 2004 XC90 AWD has been taking longer to crank lately, up to nearly 3 seconds after turning the key. By comparison, my ‘98 T5 starts immediately.
Is there something I should be checking? Thanks in advance.
Longer crank times
brunocerous
- Year and Model: 1998 V70
- Has thanked: 303 times
- Been thanked: 43 times
1998 V70 T5, AT, project
2004 XC90 AWD (sold)
1999 V70 XC AWD, AT (RIP)
1998 S70 T5, AT (RIP)
- RickHaleParker
- Been thanked: 980 times
Turn key on, wait 10 seconds then start. Make a difference?
Active
Past
Past
brunocerous
Just tried this, and it still takes just as long.
Could it be the fuel pump? Coils?
- RickHaleParker
Any DTCs ?
Active
Past
Past
- Has thanked: 1611 times
- Been thanked: 4072 times
I will throw the fuel pressure gauge in on the next 'deliver the broken engine hoist arm" trip to NJ
brunocerous
The P0441 EVAP code recently came up — in the past week or so — but it always took a little extra time to start up.
brunocerous
Oh, wow. That would be amazing!abscate wrote: 12 Aug 2020, 10:03 I will throw the fuel pressure gauge in on the next 'deliver the broken engine hoist arm" trip to NJ
I guess it can't hurt to swap out the fuel filter in the meantime.
- RickHaleParker
The maintenance interval is ten years / 60,000 miles. Is it due?brunocerous wrote: 12 Aug 2020, 15:11 I guess it can't hurt to swap out the fuel filter in the meantime.
Active
Past
Past
brunocerous
Good to know! We bought it a year ago with 80k miles on it. Fingers crossed that a new fuel filter will help. Anything else I should look to swap out?
RickHaleParker wrote: 12 Aug 2020, 15:25The maintenance interval is ten years / 60,000 miles. Is it due?brunocerous wrote: 12 Aug 2020, 15:11 I guess it can't hurt to swap out the fuel filter in the meantime.
Hold off on that fuel filter swap. It seldom helps and you can break the fittings which get you into a rabbit hole.
I’ve opened them up at 100k and found them pristine.
Look here
viewtopic.php?f=1&t=81233&p=439402#p439402
The diagnostic is fuel pressure at rail. If you don’t want to wait ( maybe next weekend?) you can buy a throwaway pencil tire pressure gauge and measure it that way. ( you throw it away because itsfull of gas)
Look here
