We really need a FYI thread about oils. Did not find it via search function.
Now to my question, can you, people, suggest the most optimal oil brand?
What engine oil brand to use? Is "Volvo" engine oil better for Volvos than other brands?
eightfifty2x0
- Year and Model: 1996 850
- Has thanked: 10 times
- Been thanked: 3 times
850oldschool
- Year and Model: 1996 850 NA
- Been thanked: 45 times
I’m a big fan of Mobil1 “European car formula”, but I don’t have a turbo, so probably a wide variety of oil would work fine.
- Has thanked: 1497 times
- Been thanked: 3809 times
This topic is beaten to death in many other places. Let’s not do that again here.
eightfifty2x0
eightfifty2x0
You mean turbo charged cars require a different oil that naturally aspirated ones?850oldschool wrote: ↑09 Aug 2020, 13:00 I’m a big fan of Mobil1 “European car formula”, but I don’t have a turbo, so probably a wide variety of oil would work fine.
eightfifty2x0
Not here, but threre. I asked here on this topic. We should really have 100 forums for 100 topics...abscate wrote: ↑09 Aug 2020, 13:20 Lots of content over here on these topics
https://www.bobistheoilguy.com/forums/
- misha
- Has thanked: 152 times
- Been thanked: 402 times
Generally....turbo engines should use full synthetic oil because of a turbo(it will last longer and will have better lubrication in all conditions).eightfifty2x0 wrote: ↑09 Aug 2020, 13:08 ...You mean turbo charged cars require a different oil that naturally aspirated ones?
Non-turbo can use regular oil,semi-synth or full synthetic...whatever you can afford and depending on your climate and driving habits.
The most important thing is that you replace it regularly along with quality oil filter.That's the main key for engine durability.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
eightfifty2x0
Hvala ti, bratemisha wrote: ↑09 Aug 2020, 13:26Generally....turbo engines should use full synthetic oil because of a turbo(it will last longer and will have better lubrication in all conditions).eightfifty2x0 wrote: ↑09 Aug 2020, 13:08 ...You mean turbo charged cars require a different oil that naturally aspirated ones?
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 73 times
Everyone seems to be particular about their oils, but the reality a lot won't admit is that any modern name-brand synthetic oil is going to do just fine in your engine. It's likely that other stuff is going to break on your car or engine prior to the oil itself truly being a factor.
Personally, I use Liqui Moly Synthoil 5W-40. Been using it for years. High quality stuff, done many 7500 mile changes with several oil analysis tests run and good wear numbers. I get it for a decent price on FCP Euro.
I have also used Mobil 1 10W-40 High Mileage for a couple 10,000 mile changes with no issues and good numbers.
About to hit 300,000 miles.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
