98 V70- What should I do while the engine is out of the car ?
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 114 times
Post by Goupil »
Hi folks,
My 98 V70 2.5T needs a few things done to pass inspection (leaking oil :mrgreen: ) and to be at a true stage 0. Odo is at 337 000km/ 209 000miles
I'm planning on getting the engine out of the car to make everything easier.
Current plan is:
- Timing belt
- Clutch
- oil pan gasket
- oil pan/pickup seals
- rear main seal
- hydraulic engines mounts
- A/C compressor ? (mine is most likely cooked)
Is there anything else worth replacing while the engine is out ? I'd rather take 20min to fix something than have it fail later with the engine back in :D
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
theWIFES_S70
Year and Model: 1998 S70 base
Has thanked: 61 times
Been thanked: 37 times
Post by theWIFES_S70 »
That looks pretty good. I guess you could take care of the oil pump seal/gaskets. But those things rarely fail. Post pics!!
Retired:
2015 Volvo S60, T5, 85K
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
I would look hard at doing those hard to reach things like water pump, serpentine belt, Idlers, PCV system, alternator brushes (?), and maybe the power steering hoses if they have not been renewed. Those hoses are a real pain to replace when they go bad.
Goupil
Post by Goupil »
theWIFES_S70 wrote: 09 Aug 2020, 14:30 That looks pretty good. I guess you could take care of the oil pump seal/gaskets. But those things rarely fail. Post pics!!
The gasket kit looks cheap, but that might be one of those things that you shouldn't fix if it aint broke :?:
I will have to do a bit of research on that topic
volvolugnut wrote: 09 Aug 2020, 14:36 I would look hard at doing those hard to reach things like water pump, serpentine belt, Idlers, PCV system, alternator brushes (?), and maybe the power steering hoses if they have not been renewed. Those hoses are a real pain to replace when they go bad.
Should I replace the water pump ? I've read that anything but Volvo OEM is garbage, and if it's fine it shouldn't be replaced, is that true ?
Serpentine aren't that bad, did one yesterday on a 850 :mrgreen:
I replaced the PCV a year 1/2 ago (about 25k miles), I might just buy a new one and replace it if it looks clogged.
Good call on the power steering hoses, I'll go check what state they are in tomorrow
If it is time to service any of the parts I suggested, it would be easier with engine out. If parts are known to be within service life, I would not change them. On water pump, use only Aisin (original Volvo supplier). A water pump or idler failure can take out the timing belt and result in bent valves. Search MVS for replacement intervals.
Also consider coolant hoses while you are apart - hose failure can require a head gasket if you over heat.
FLXC90
Year and Model: 98 V70 T5
Has thanked: 16 times
Been thanked: 45 times
Post by FLXC90 »
and a thorough examination of ALL hoses, heater, power steering, vacuum, check wiring looms for bad spots, clean ground points. Are you pulling just the engine, or eng/trans, up or dropping subframe?
Current Volvos:
jeffsws
Year and Model: 850 NA 1997
Has thanked: 3 times
Been thanked: 3 times
Post by jeffsws »
I would also clean up the engine bay now that it's empty. Oil, dirt, rust etc...
callahanoffroad
Year and Model: 1995 850
Been thanked: 53 times
Post by callahanoffroad »
With the engine out it's also a great time to replace the power steering rack, and rebuild the power steering lines. As well as replace all the heater hoses. Plus everything else that's been suggested. Honestly your budget is the deciding factor. I'd also do a compression test, and inspect the intake and exhaust valves seats to see if they need to be replaced.
Hell. Just rebuild the engine, while you're at it :-D
Author, Chef, and Shade Tree Mechanic
1995 Volvo 850, Non-Turbo, VVIS, LH FI, Green, 215,000 miles. B5254FS engine. Herman. viewtopic.php?f=1&t=84393
1996 Volvo 850, died at 280,000
Founder of: CookingForChemo.Org
Read my Silly Comic Book at: therealpizzabros.com/
Has thanked: 311 times
Been thanked: 817 times
Post by erikv11 »
Definitely inspect the PS hoses and PS rack. Much, much easier to do now if needed.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
I wouldn't worry about the oil pump gasket/seals.
Adding to the list, front crank seal and cam seals. Might as well tackle all that while the engine is out and apart!
Possibly the PCV too if it hasn't been done.
