Volvo died on the road. Sputtered, died, could restart once to get off road, but then died again for good.
Towed home. Put in new plugs, new coils. Have spark on 4 out of 5 coils. Number 5 has no spark, and I can see the insulation on the wires going to it is shot. Will replace that, but one bad coil shouldn't keep it from starting.
Fuel rail has pressure. Poured a tiny glug of gasoline down the air tube to the trottle to see if that would at least make it hit a lick. Nothing.
Cranks, but won't hit. Running out of ideas. Maybe crankshaft position sensor went dead? Maybe ECM relay?
06 v70 Will Crank, Won't start, Has Spark
- Has thanked: 987 times
- Been thanked: 1075 times
Do you have a code reader? Does it have any stored codes? Current battery voltage? These Volvos do not like weak batteries - cranking may not indicate proper voltage to run.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Possible you have no spark on any plug , sounds like the ignition wiring harness is failing.rswearing wrote: 17 Aug 2020, 17:23 Volvo died on the road. Sputtered, died, could restart once to get off road, but then died again for good.
A weak spark in open air will not spark under compression.
rswearing
- Year and Model: 2006 Volvo V70 2.5T
I think I've narrowed this down to crackshaft position sensor. Just idiot proofing myself here...I pulled it, but it looks a little different than what's available to order online.
Came off of where transmission meets the block, under the airbox, beween firewall and neutral safety switch. I'm like 93% cofindent this is the right sensor, but the ones online have a 90 degree turn at the connector instead of straight on like this one.
Resistance test is way off.
This would explain the rough running I've been having, the sudden death in the road, and the failure to start.
rswearing
"Possible you have no spark on any plug , sounds like the ignition wiring harness is failing.
A weak spark in open air will not spark under compression."
With the exception of the number 5 coil, was throwing a nice arc from screwdriver to ground over about a half inch. Would that qualify as weak or good spark? Not sure.
- jonesg
yes thats a good healthy jolt.rswearing wrote: 19 Aug 2020, 18:07 "Possible you have no spark on any plug , sounds like the ignition wiring harness is failing.
looks like you got it sorted out..
rswearing
Returning to this.
New crank sensor installed. Still no start.
Pulled fuel rail off to take a look at injectors. They look ok, but with the rail off there is NO fuel coming up the fuel line when ignition is in on position or even when engine is cranked. That may be a failsafe with the fuel rail disconnected, but it seems like there should be fuel coming through the line. Fuel pump whirs inside the tank when iginition position is on, so I think the pump is good. New filter, so that's not it. Now thinking PEM?
Is there a way to bench test the PEM before I order a new one?
Note - also getting a high pitched whine from the rear VVT solenoid that I'm not sure should be happening. Whines when ignition is turned on, and persists after ignition is off. Is this normal?
- 17 Replies
- 2692 Views
Last post by Dingo957
- 3006 Views
Last post by Roger_850T
- 1123 Views
Last post by nmotzing
- 49 Replies
- 10758 Views
- 3451 Views
Last post by Empathron
